roi跟随和仿射变幻
cuiben 发表于 2023-5-13 14:33:54 | 显示全部楼层 |阅读模式
想求个根据模型匹配,进行图像跟随,并对图像进行仿射变幻
吐个泡泡 发表于 2023-5-15 22:05:41 | 显示全部楼层
read_image (Image1, 'D:/Picture/1.bmp')
dev_close_window ()
dev_open_window_fit_image (Image1, 0, 0, -1, -1, WindowHandle)
dev_display (Image1)
*创建一个模板匹配,并得到初始模板行、列、角度
draw_rectangle1 (WindowHandle, Row1, Column1, Row2, Column2)
gen_rectangle1 (Rectangle, Row1, Column1, Row2, Column2)
reduce_domain (Image1, Rectangle, ImageReduced)
create_shape_model (ImageReduced, 'auto', rad(0), rad(360), 'auto', 'auto', 'use_polarity', 'auto', 'auto', ModelID)
find_shape_model (ImageReduced, ModelID, rad(0), rad(360), 0.5, 1, 0.5, 'least_squares', 0, 0.5, Row, Column, Angle, Score)
dev_display_shape_matching_results (ModelID, 'red', Row, Column, Angle, 1, 1, 0)
stop()
*创建带角度的矩形ROI,得到行、列坐标
draw_rectangle2 (WindowHandle, Row3, Column3, Phi, Length1, Length2)
gen_rectangle2 (Rectangle1, Row3, Column3, Phi, Length1, Length2)
stop()
for i := 0 to rad(360) by rad(10)
    *生成旋转图像,产生识别、ROI跟随旋转效果
    vector_angle_to_rigid (575, 558, 0, 575, 558, i, HomMat2D)
    affine_trans_image (Image1, ImageAffineTrans, HomMat2D, 'constant', 'false')
    *找模板
    find_shape_model (ImageAffineTrans, ModelID, rad(0), rad(360), 0.5, 1, 0.5, 'least_squares', 0, 0.5, Row11, Column11, Angle11, Score)
    *得到相对于初始模板行、列坐标的变换矩阵
    vector_angle_to_rigid (Row, Column, Angle, Row11, Column11, Angle11, HomMat2D1)
    *利用变换矩阵变换ROI行、列坐标,得到行动ROI行、列坐标
    affine_trans_pixel (HomMat2D1, Row3, Column3, RowTrans, ColTrans)
    *利用行动行、列坐标生成ROI
    gen_rectangle2 (Rectangle2, RowTrans, ColTrans, Angle11+Phi, Length1, Length2)
    dev_display (ImageAffineTrans)
    dev_display (Rectangle2)
    wait_seconds (1)
    *stop()
endfor
2910372828 发表于 2023-5-31 00:31:33 | 显示全部楼层
学习一下
zrp785962235 发表于 2023-7-7 09:22:00 | 显示全部楼层
感谢分享,学习了
多看就会 发表于 2023-7-21 13:37:24 | 显示全部楼层
会了,顶一下。。。。。。。
jackwangyb222 发表于 2023-8-1 19:03:24 | 显示全部楼层
感谢分享,学习了
