返回列表 发新帖
HalconDotNet dump_window problem.
Criss 发表于 2021-5-27 13:41:06 | 显示全部楼层
Evgeniy 发表于 2021-5-26 22:47
Criss, thank you!
Very interesting example.
hi,nice to meet you! i found this problem is maybe you create window handle by procedure like dev_open_window occurred,it's wrong!the window handle just need transfer into hdev file from outside,i changed my code for your issue.it's works too.
https://1drv.ms/u/s!AgtcKzAtnq7fiz8gvdaIZlosCsop?e=hSYwFc
 楼主| Evgeniy 发表于 2021-5-28 12:30:38 | 显示全部楼层
Hi, Criss! Nice to meet you too.
That you showed me is incredible!!! And this really works fine!!! Fantastic example and that is what I wanted!!! I did update with your example.
https://drive.google.com/file/d/1cR6Zqvo5spCL3ZWeturz2mtiNzw-1MQ3/view?usp=sharing
 楼主| Evgeniy 发表于 2021-5-28 12:34:34 | 显示全部楼层
Need to label your example as solution!
Criss 发表于 2021-5-28 13:48:22 | 显示全部楼层
you're welcome!
