[文档] halcon中的RGB到任意颜色空间转换
绝地武士 发表于 2023-7-12 18:30:33 | 显示全部楼层 |阅读模式
trans_from_rgb 转换图像RGB到任意颜色空间
  1. trans_from_rgb(ImageRed, ImageGreen, ImageBlue : ImageResult1, ImageResult2, ImageResult3 : ColorSpace : )
支持图像类型:byte, uint2, int4, real(real类型下图像值只能是0和1,否则结果不可预料)
颜色空间:
'yiq'
取值范围:
'yuv'
取值范围:
'argyb'
取值范围:
'ciexyz'
所使用的原色sRGB分别对应于CIE Rec. 709以及用作白点D65。
使用的原色(x,y,z):
取值范围:
'hls'
  1. Min := min([R, G, B])
  2.   Max := max([R, G, B])
  3.   L := (Min + Max) / 2
  4.   if (Max == Min)
  5.      H := 0
  6.      S := 0
  7.   else
  8.      if (L > 0.5)
  9.         S := (Max - Min) / (2 - Max - Min)
  10.      else
  11.         S := (Max - Min) / (Max + Min)
  12.      endif
  13.      if (R == Max)
  14.         H := ((G - B) / (Max - Min)) * rad(60)
  15.      elseif (G == Max)
  16.         H := (2 + (B - R) / (Max - Min)) * rad(60)
  17.      elseif (B == Max)
  18.         H := (4 + (R - G) / (Max - Min)) * rad(60)
  19.      endif
  20.   endif
取值范围:
'hsi'
取值范围:
'hsv'
  3.   V := Max
  4.   if (Max == Min)
  5.      S := 0
  6.      H := 0
  7.   else
  8.      S := (Max - Min) / Max
  9.      if (R == Max)
  10.         H := ((G - B) / (Max - Min)) * rad(60)
  11.      elseif (G == Max)
  12.         H := (2 + (B - R) / (Max - Min)) * rad(60)
  13.      elseif (B == Max)
  14.         H := (4 + (R - G) / (Max - Min)) * rad(60)
  15.      endif
  16.   endif
取值范围:
'ihs'
  3.    I := (R + G + B) / 3
  4.    if (I == 0)
  5.       H := 0
  6.       S := 1
  7.    else
  8.       S := 1 - Min / I
  9.       if (S == 0)
  10.            H := 0
  11.       else
  12.          X := (R + R - G - B) / 2
  13.          Y := (R - G) * (R - G) + (R - B) * (G - B)
  14.          Z := sqrt(Y)
  15.          if (Z == 0)
  16.             H := 0
  17.          else
  18.             H := acos(X / Z)
  19.          endif
  20.          if (B > G)
  21.             H := rad(360) - H
  22.          endif
  23.       endif
  24.    endif
取值范围:
'cielab'
其中
  1. f(t) = t^(1/3),           t > (24/116)^3
  2.      f(t) = (841/108)*t + 16/116,  otherwise.
  3.      Black point B: (Rb, Gb, Bb) = (0, 0, 0)
  4.      White point W = (Rw, Gw, Bw), according to image type:
  5.        byte:=(255, 255, 255), uint2:=(2^16-1, 2^16-1, 2^16-1),
  6.        int4:=(2^31-1, 2^31-1, 2^31-1), real:=(1.0, 1.0, 1.0)
取值范围:
'cielchab'
其中
  3.      h_ab lies between 0° and 90° if a and b are both positive,
  4.      between 90° and 180° if a is negative and b is positive,
  5.      between 180° and 270° if a and b are both negative, and
  6.      between 270° and 360° if a is positive and b is negative.
  7.      Black point B: (Rb, Gb, Bb) = (0, 0, 0)
  8.      White point W = (Rw, Gw, Bw), according to image type:
  9.        byte:=(255, 255, 255), uint2:=(2^16-1, 2^16-1, 2^16-1),
  10.        int4:=(2^31-1, 2^31-1, 2^31-1), real:=(1.0, 1.0, 1.0)
取值范围:
'cieluv'
其中
取值范围:
'cielchuv'
其中
  3.      h_uv lies between 0° and 90° if u and v are both positive,
  4.      between 90° and 180° if u is negative and v is positive,
  5.      between 180° and 270° if u and v are both negative, and
  6.      between 270° and 360° if u is positive and v is negative.
取值范围:
'i1i2i3'
取值范围:
'ciexyz2'
取值范围:
'ciexyz3'
取值范围:
'ciexyz4'
使用的原色(x, y, z)
取值范围:
'lms'
从概念上讲,这是从RGB到CIEXYZ的转换(见上面的"CIEXYZ"),然后是从CIEXYZ到LMS的转换。
取值范围:
参考例子:
  1. read_image(Image,'patras')
  2. dev_display(Image)
  3. decompose3(Image, Image1, Image2, Image3)
  4. trans_from_rgb(Image1,Image2,Image3,ImageH,ImageS,ImageV,'hsv')
  5. trans_to_rgb(ImageH,ImageS,ImageV,ImageR,ImageG,ImageB,'hsv')
  6. compose3(ImageR,ImageG,ImageB,Multichannel)
  7. dev_display(Multichannel)
Ggg3434 发表于 2023-7-13 09:29:12 | 显示全部楼层
学习一下
老老常 发表于 2023-7-13 15:23:58 | 显示全部楼层
牛皮牛皮,学习了。它那个不同颜色的转换系数是怎么来的?
shimi20 发表于 2023-7-19 17:38:27 | 显示全部楼层
谢谢分享,刚刚开始学习,虽然还看不懂,感觉很厉害的样子,先收藏了
qqdewomen 发表于 2023-7-23 10:56:32 | 显示全部楼层
感谢大佬,学习学习
Mbot 发表于 2023-8-1 16:24:22 | 显示全部楼层
牛皮牛皮,学习了。
诸葛释冰 发表于 2023-8-21 14:21:53 | 显示全部楼层
livehu5188 发表于 2023-10-5 22:45:07 | 显示全部楼层
刚学 还是有点看不懂
freekun139com 发表于 2023-10-8 09:48:12 | 显示全部楼层
学习一下,测试了大半天终于差不多搞明白了,感谢楼主分享
RGB到HSV转换测试.hdev (3.15 KB, 下载次数: 1)
李li 发表于 2023-10-16 07:47:19 | 显示全部楼层
谢谢分享,虽然还看不懂,先收藏了
