字符OCR识别,新人求助
夜问夜问 发表于 2023-11-28 13:37:05 | 显示全部楼层 |阅读模式
我是新人练习OCR字符识别,字符一直无法识别,不知道是问题出现在哪里,求助各位高手指点迷津谢谢!
  1. dev_close_window ()
  2. dev_open_window (0, 0, 512, 512, 'black', WindowHandle)
  3. read_image (Image, 'C:/Users/WP/Desktop/测试图像.jpg')
  4. rotate_image (Image, Image1, 4, 'constant')
  5. *画矩形
  6. draw_rectangle1 (WindowHandle, Row1, Column1, Row2, Column2)
  7. gen_rectangle1 (ModelRegion, Row1, Column1, Row2, Column2)
  8. *分割图像
  9. reduce_domain (Image1, ModelRegion, ModelRegionImage)
  10. *将分割后的图像放大显示
  11. crop_domain (ModelRegionImage, ImagePart)
  12. *图像增强
  13. equ_histo_image (ImagePart, ImageEquHisto)
  14. *增强图像对比度
  15. * emphasize (ImagePart, ImageEmphasize, 7, 7, 1)
  16. *图像进行旋转
  17. * rotate_image (ImageEmphasize, ImagePart, 4, 'constant')
  18. *将图片写入保存本地
  19. write_image (ImagePart, 'tiff', 0, 'C:/Users/WP/Desktop/test.bmp')
  20. decompose3 (ImagePart, r, g, b)
  21. trans_from_rgb (r, g, b, h, s, v, 'hsv')
  22. *进行阈值分割
  23. threshold (b, Regions, 38, 255)
  24. connection (Regions, ConnectedRegions)
  25. select_shape (ConnectedRegions, SelectedRegions, ['row','column'], 'and', [69.44,86.11], [212.04,499.07])
  26. union1 (SelectedRegions, RegionUnion)
  27. shape_trans (RegionUnion, RegionTrans, 'rectangle1')
  28. * partition_rectangle (RegionTrans, Partitioned, 50, 50)
  29. dev_display (b)
  30. intersection (b, RegionUnion, RegionIntersection)
  31. sort_region (RegionIntersection, SortedRegions, 'character', 'true', 'column')
  32. read_ocr_class_mlp ('Pharma_0-9A-Z_NoRej.omc', OCRHandle)
  33. do_ocr_multi_class_mlp (ConnectedRegions, Image1, OCRHandle, Class, Confidence)
  34. disp_message (WindowHandle, Class, 'Image', 80, Column1 + 80, 'green', 'false')
Ggg3434 发表于 2023-11-28 13:56:22 | 显示全部楼层
正常识别是白底黑字的,你看你图像反转了么
 楼主| 夜问夜问 发表于 2023-11-28 13:57:43 | 显示全部楼层
图片是斜的我旋转了一下
Ggg3434 发表于 2023-11-28 13:57:44 | 显示全部楼层
方便的话贴一下原图
 楼主| 夜问夜问 发表于 2023-11-28 14:02:19 | 显示全部楼层
原图太大了我处理了一下不过也可以
Ggg3434 发表于 2023-11-28 14:13:50 | 显示全部楼层
原图太大了我处理了一下不过也可以
这边你看下效果,只做了上面大的字体识别
 楼主| 夜问夜问 发表于 2023-11-28 14:16:27 | 显示全部楼层
我是不是图像没有处理好呀
Ggg3434 发表于 2023-11-28 14:18:49 | 显示全部楼层
我是不是图像没有处理好呀
你这个例子不太需要什么处理,我只是在我之前测试OCR代码上改了一点点就能识别出来了
Ggg3434 发表于 2023-11-28 14:20:02 | 显示全部楼层
我是不是图像没有处理好呀
  1. read_image(Image, '3')
  2. get_image_size(Image, Width, Height)
  3. dev_open_window(0, 0, Width, Height, 'black', WindowHandle)
  4. dev_display(Image)
  5. decompose3 (Image, Image1, Image2, Image3)
  7. gen_rectangle1 (Rectangle, Row1, Column1, Row2, Column2)
  8. reduce_domain (Image3, Rectangle, ImageReduced)
  9. invert_image (ImageReduced, ImageInvert)
  10. threshold (ImageReduced, Region, 90, 255)
  11. connection (Region, ConnectedRegions)
  12. select_shape (ConnectedRegions, SelectedRegions, 'area', 'and', 10, 50)
  13. sort_region(SelectedRegions, SortedRegions1, 'character', 'true', 'row')
  14. shape_trans (SortedRegions1, Characters, 'rectangle1')
  15. read_ocr_class_mlp('Document_A-Z+_NoRej.omc', OCRHandle)
  16. T:=''
  17. do_ocr_word_mlp(Characters, ImageInvert, OCRHandle, T, 3, 1, Class, Confidence, Word, Score)
  18. clear_ocr_class_mlp(OCRHandle)
  19. set_display_font(WindowHandle, 16, 'mono', 'true', 'false')
  20. disp_message(WindowHandle, Word, 'window', 10, 10, 'black', 'true')
代码给你可以看看
 楼主| 夜问夜问 发表于 2023-11-28 16:26:50 | 显示全部楼层
dev_open_window(0, 0, Width, Height, ' ...
还是大佬比较厉害,我这新手都搞不清楚图像处理遵循那些步骤
