*创建模板
Names := [0,1]
*模板路径用到的数组
Models := []
*创建模板
for i := 0 to 1 by 1
read_image (Image, './Model/' + Names[i] + '.bmp')
get_image_size (Image, OriginWidth, OriginHeight)
zoom_image_factor (Image, Imagezoom, 0.4, 0.4, 'constant')
get_image_size (Imagezoom, ZoomWidth, ZoomHeight)
dev_update_off ()
dev_close_window ()
dev_open_window_fit_image (Imagezoom, 0, 0, ZoomWidth, ZoomHeight, WindowHandle)
dev_display (Imagezoom)
set_display_font (WindowHandle, 16, 'mono', 'true', 'false')
dev_set_color ('red')
dev_set_line_width (3)
if (i = 0)
disp_message (WindowHandle, '创建正面模板', 'window', 12, 12, 'lime green', 'false')
elseif (i = 1)
disp_message (WindowHandle, '创建反面模板', 'window', 12, 12, 'lime green', 'false')
endif
draw_circle (WindowHandle, Rows, Columns, Radiuss)
gen_circle (ROI_0, Rows, Columns, Radiuss)
reduce_domain (Imagezoom, ROI_0, ImageReduced)
create_shape_model (ImageReduced, 'auto', 0, rad(360), 'auto', 'auto', 'use_polarity', 'auto', 'auto', ModelID)
Models := [Models,ModelID]
area_center (ROI_0, Area, Row, Column)
dev_clear_window ()
dev_display_shape_matching_results (ModelID, 'red', Row, Column, 0.0, 1.0, 1.0, 0)
disp_message (WindowHandle, '模板已创建', 'window', 12, 12, 'lime green', 'false')
stop ()
endfor
*匹配模板
Scores := []
count0 := 0
count1 := 0
error := 0
list_files ('E:/Test/project/Halcon18.11-MatchingDegree/Image', ['files','follow_links'], ImageFiles)
tuple_regexp_select (ImageFiles, ['\\.(tif|tiff|gif|bmp|jpg|jpeg|jp2|png|pcx|pgm|ppm|pbm|xwd|ima|hobj)$','ignore_case'], ImageFiles)
for Index := 0 to |ImageFiles| - 1 by 1
dev_clear_window ()
read_image (Image, ImageFiles[Index])
count_seconds (Seconds1)
zoom_image_factor (Image, Imagezooms, 0.4, 0.4, 'constant')
find_shape_models (Imagezooms, Models, 0, rad(360), 0.2, 1, 0.0, 'least_squares', 9, 0.9, Row1, Column1, Angle, Score, Model)
count_seconds (Seconds2)
Scores := [Scores, Score]
if (Model = 0)
dev_display (Imagezooms)
dev_display_shape_matching_results (Models[0], 'red', Row1, Column1, Angle, 1.0, 1.0, 0)
disp_message (WindowHandle, '正面' + ' Match found in ' + ((Seconds2 - Seconds1) * 1000.0)$'.1f' + ' ms', 'window', 12, 12, 'lime green', 'false')
count0 := count0 + 1
elseif(Model = 1)
dev_display_shape_matching_results (Models[1], 'red', Row1, Column1, Angle, 1.0, 1.0, 0)
disp_message (WindowHandle, '反面' + ' Match found in ' + ((Seconds2 - Seconds1) * 1000.0)$'.1f' + ' ms', 'window', 12, 12, 'lime green', 'false')
count1 := count1 + 1
else
error := error + 1
endif
stop()
endfor
*释放一个轮廓模型的内存
clear_shape_model(ModelID)
