Halcon自标定:stationary_camera_self_calibration
小白白213 发表于 2025-5-14 16:04:44 | 显示全部楼层 |阅读模式
悬赏49视觉币
代码如下:
  1. read_image(Images, ['D:/pycharm/3D_positioning_function_experiment/dataset/rotate_image_dataset/101[205, 5.0, 1.0].jpg','D:/pycharm/3D_positioning_function_experiment/dataset/rotate_image_dataset/101[184.1, -5.0, 1.0].jpg','D:/pycharm/3D_positioning_function_experiment/dataset/rotate_image_dataset/101[184.1, 15.4, 1.0].jpg','D:/pycharm/3D_positioning_function_experiment/dataset/rotate_image_dataset/101[221.3, 13.7, 1.0].jpg'])
  2. From := [1,1,1,2,2,3]
  3. To := [2,3,4,3,4,4]
  4. HomMatrices2D := []
  5. Rows1 := []
  6. Cols1 := []
  7. Rows2 := []
  8. Cols2 := []
  9. NumMatches := []
  10. for J := 0 to |From|-1 by 1
  11.     select_obj (Images, ImageF, From[J])
  12.     select_obj (Images, ImageT, To[J])
  13.     points_foerstner (ImageF, 1, 2, 3, 100, 0.1, 'gauss', 'true', \
  14.                       RowsF, ColsF, _, _, _, _, _, _, _, _)
  15.     points_foerstner (ImageT, 1, 2, 3, 100, 0.1, 'gauss', 'true', \
  16.                       RowsT, ColsT, _, _, _, _, _, _, _, _)
  17.     proj_match_points_ransac (ImageF, ImageT, RowsF, ColsF, RowsT, ColsT, \
  18.                               'ncc', 10, 0, 0, 2560, 1440, 0, 0.5, \
  19.                               'gold_standard', 2, 42, HomMat2D, \
  20.                               Points1, Points2)
  21.     HomMatrices2D := [HomMatrices2D,HomMat2D]
  22.     Rows1 := [Rows1,subset(RowsF,Points1)]
  23.     Cols1 := [Cols1,subset(ColsF,Points1)]
  24.     Rows2 := [Rows2,subset(RowsT,Points2)]
  25.     Cols2 := [Cols2,subset(ColsT,Points2)]
  26.     NumMatches := [NumMatches,|Points1|]
  27. endfor
  28. stationary_camera_self_calibration (4, 2560, 1440, 1, From, To, \
  29.                                     HomMatrices2D, Rows1, Cols1, \
  30.                                     Rows2, Cols2, NumMatches, \
  31.                                     'gold_standard', \
  32.                                     ['focus','principal_point'], \
  33.                                     'true', CameraMatrix, Kappa, \
  34.                                     RotationMatrices, X, Y, Z, Error)
求助1:stationary_camera_self_calibration报错:未处理的程序异常:
HALCON 算子错误
当在函数 'main' 中调用 'stationary_camera_self_calibration'时。line: 28。
Wrong number of values of control parameter 7 (HALCON 错误代码: 1407)
求助2:我想把待匹配的点变为棋盘格内角点 这个代码应该怎么写?
 楼主| 小白白213 发表于 2025-5-14 16:05:53 | 显示全部楼层
大佬们 求助求助!!!!!
Criss 发表于 2025-5-15 09:01:03 | 显示全部楼层
你这做相机自身校准是为了?一般我们用7x7圆点或者棋盘格来校准相机镜头畸变的。
topqaz123 发表于 2025-5-19 13:34:27 | 显示全部楼层
{:1_6:}{:1_6:}
