设为首页收藏本站 距【华南国际工业博览会】开幕 : :
查看: 2219|回复: 1
收起左侧
[已解决] 关于 orientation_region 区域定向的问题
    耍酷
    2020-10-27 15:39
  • 签到天数: 14 天
    12
    99
    发表于 2018-1-23 15:07:55 | 显示全部楼层 |阅读模式
    orientation_region 区域定向,指定方向的规则是什么呢?
    昨天 10:10
  • 签到天数: 1064 天
    连续签到: 18 天
    394
    1604
    7942
    发表于 2018-6-22 22:15:07 | 显示全部楼层
    基于算子 elliptic_axis等效区域为椭圆的参数来进行区域角度的认定!
    怎么计算呢?官方的文档解释如下:
    1. The operator orientation_region calculates the orientation of the region. The operator is based on elliptic_axis. In addition the point on the contour with maximal distance to the center of gravity is calculated. If the column coordinate of this point is less than the column coordinate of the center of gravity the value of Pi is added to the angle.
    2. If more than one region is passed the results are stored in tuples, the index of a value in the tuple corresponding to the index of a region in the input.
    大概意思就是计算椭圆轮廓到重心的最大距离的点,如果该点的列坐标小于重心列坐标,那么就将这个点的PI值加到角度当中!
