设为首页收藏本站 距【华南国际工业博览会】开幕 : :
查看: 2657|回复: 4
收起左侧
[待解决] 微信跳一跳简单图像识别方法
146
发表于 2018-1-28 13:16:49 | 显示全部楼层 |阅读模式
我想到的第一个方法: (缺陷是只能对图像颜色深度高的)
  1. dev_set_draw ('margin')
  2. read_image (Image, 'C:/Users/6013_1.jpeg')
  3. stop ()
  4. rgb1_to_gray(Image, GrayImage)
  5. threshold (Image, Regions, 0, 135)
  6. opening_rectangle1 (Regions, RegionOpening, 15, 15)
  7.
  8. connection(RegionOpening, ConnectedRegions)
  9. select_shape (ConnectedRegions, SelectedRegions, 'area', 'and', 20045.9, 30137.6)
  10. opening_rectangle1 (SelectedRegions, RegionOpening1, 35, 35)
  11. count_obj (RegionOpening1, Number)
  12. for Index := 1 to Number by 1
  13.     select_obj (RegionOpening1, ObjectSelected, Index)
  14.     smallest_rectangle2 (ObjectSelected, Row, Column, Phi, Length1, Length2)
  15.     area_center (ObjectSelected, Area, Row1, Column1)
  16.     gen_circle (Circle, Row1, Column1, 5)
  17.     gen_rectangle2 (ObjectSelected, Row, Column, Phi, Length1, Length2)
  18. endfor
第二版改进了下按照区域连同 + 面积选择 来做. 基本实现了简单图形的功能
  1. *dev_set_draw ('margin')
  2. read_image (Image, 'C:/Users/Administrator/Desktop/t1t/IMG_2330.PNG')
  3. stop ()
  5. mean_image (GrayImage, ImageMean, 9, 9)
  6. regiongrowing (ImageMean, Regions, 3, 3, 1, 300)
  7. select_shape (Regions, SelectedRegions, 'area', 'and', 11592.2, 30018.2)
  8.
  9. count_obj (SelectedRegions, Number)
  10. for Index := 1 to Number by 1
  11.     select_obj (SelectedRegions, ObjectSelected, Index)
  12.     area_center (ObjectSelected, Area, Row1, Column1)
  13.     gen_circle (Circle, Row1, Column1, 5)
  14. endfor
嗯..如果遇到复杂的图像,还是差强人意. 所以我重新写了个专门找找小人的代码
  1. read_image (Image, 'C:/Users/Administrator/Desktop/t1t/IMG_2339.PNG')
  2. stop ()
  3. rgb1_to_gray(Image, GrayImage)
  4.
  5. scale_image (GrayImage, ImageScaled1, 7.72727, -394)
  6. threshold (ImageScaled1, Regions, 0, 253)
  7. erosion_circle (Regions, RegionErosion, 15)
  8. fill_up (RegionErosion, RegionFillUp)
  9. area_center (RegionFillUp, Area, Row1, Column1)
  10. gen_circle (Circle, Row1, Column1, 5)
再复杂的图像,例如下面的,矩形里有很多条纹,就不知道怎么处理好点了, 另外还有个 魔方 样式的..
这两天想利用模板匹配来识别, 还在研究,不知道效果如何
    5 小时前
  • 签到天数: 1064 天
    连续签到: 18 天
    394
    1603
    7940
    发表于 2018-1-28 13:55:11 | 显示全部楼层
    好像很厉害的样子哦!图像算法部分应该还好吧,找到每个屏幕对应的分辨率,对应的像素中心偏差和每个像素大概的时间大小就可以接近目标按压的时间了!图像部分主要要分割每个区域单独的最大的矩形或者圆形,然后需要定位小人所在的位置,模板定位可以搞定。
    146
     楼主| 发表于 2018-1-28 14:34:39 | 显示全部楼层
    51Halcon 发表于 2018-1-28 13:55
    好像很厉害的样子哦!图像算法部分应该还好吧,找到每个屏幕对应的分辨率,对应的像素中心偏差和每个像素大 ...
    嗯, 新学hc , 模板匹配正在实验, 可能我模板物体选的太多了(其实是每种形状都弄成了个单独模板,汗) , 然后匹配的时候总是匹配到比实际更多,:L , 路漫漫,哈
    146
     楼主| 发表于 2018-1-30 17:20:34 | 显示全部楼层
    第四版:
    利用查找边缘 , 滤波之后按照行坐标排序,提取第一个边缘线, 画出这个边缘线的最小外接圆, 获取到外接圆的圆心坐标 即为 下一个跳板的中心坐标.
    小人坐标继续利用上面的方法实现.
    存在的问题: 可能边缘方法用的不好, 外接圆有时候圆心会靠边缘. 估计实际测试中有可能会跳出跳板导致摔死......
    抛砖引玉吧, 这个边缘未进行优化和处理, 主要是刚刚接触halcon , 希望有人能购优化以下, 跳的更准点.......
    工程下载: 跳一跳.zip (948.16 KB, 下载次数: 15)
    146
     楼主| 发表于 2018-1-30 17:22:20 | 显示全部楼层
    下面这张就是代码中的bg.png图片了.. 就是跳一跳的纯色背景
    背景图
    背景图
