设为首页收藏本站 距【华南国际工业博览会】宝安新馆开幕 : :
查看: 1801|回复: 1
[待解决] 双目三维测量得到的高度与实际差好多
4
40
发表于 2018-8-21 13:22:45 | 显示全部楼层 |阅读模式
标定部分代码:
binocular_calibration (X, Y, Z, RowsL, ColsL, RowsR, ColsR, StartCamParL, StartCamParR, StartPosesL, StartPosesR, 'all', CamParamL, CamParamR, NFinalPoseL, NFinalPoseR, cLPcR, Errors)
双目矫正的代码:
gen_binocular_rectification_map (MapL, MapR, CamParamL, CamParamR, cLPcR, 1, 'geometric', 'bilinear', RectCamParL, RectCamParR, CamPoseRectL, CamPoseRectR, RectLPosRectR)
读取矫正后的标定图,提取圆心坐标,并求得三维坐标:
read_image (ImageMapped1, ImgPath + 'L_rec1')
read_image (ImageMapped2, ImgPath + 'R_rec1')
dev_set_window (WindowHandle1)
dev_display (ImageMapped1)
dev_set_window (WindowHandle2)
dev_display (ImageMapped2)
find_caltab (ImageMapped1, CaltabL_rec, 'caltab_0.6.descr', 3, 112, 5)
find_marks_and_pose (ImageMapped1, CaltabL_rec, 'caltab_0.6.descr', RectCamParL, 128, 10, 18, 0.9, 15, 100, RCoordL_rec, CCoordL_rec, StartPose1)
disp_caltab (WindowHandle1, CaltabFile, RectCamParL, StartPose1, 1)
find_caltab (ImageMapped2, CaltabR_rec, 'caltab_0.6.descr', 3, 112, 5)
find_marks_and_pose (ImageMapped2, CaltabR_rec, 'caltab_0.6.descr', RectCamParR, 128, 10, 18, 0.9, 15, 100, RCoordR_rec, CCoordR_rec, StartPose2)
disp_caltab (WindowHandle2, CaltabFile, RectCamParR,StartPose2 , 1)
*stop()
Disparity := CCoordR_rec - CCoordL_rec
disparity_to_distance (RectCamParL, RectCamParR, RectLPosRectR, Disparity, Distance)
disparity_to_point_3d (RectCamParL, RectCamParR, RectLPosRectR, RCoordL_rec, CCoordL_rec, Disparity, X, Y, Z)
pose_to_hom_mat3d (CamPoseRectL, c1Trect1)
affine_trans_point_3d (c1Trect1, X, Y, Z, c1X, c1Y, c1Z)
标定误差为0.1pixl,矫正误差也是0.1,得到的c1Z数值与真实距离查了十几厘米.
这里的X, Y, Z, c1X, c1Y, c1Z 单位是m吗?
    2018-9-7 12:32
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    16
    40
    发表于 2018-8-21 17:59:44 | 显示全部楼层
    是m,注意单位换算
