TA的每日心情 | 害羞 2018-8-6 09:08 |
签到天数: 40 天 连续签到: 1 天 [LV.5]常住居民I
- 积分
- 628
显示图片是用 pictureBox1来显示的,它的代码如下,因为获得图像显示后还要进行图像处理,放到halcon里使用Hobject 的图像变量,
但是我写了 Hobject image= camera.BitMap;却报错,请问如何获得这个图像变量呢?
下面是显示图像的所有代码,
void camera_UpdateImage()
pictureBox1.Image = camera.BitMap;
public static void CreateBitmap(out Bitmap bitmap, int width, int height, bool color)
bitmap = new Bitmap(width, height, GetFormat(color));
if (bitmap.PixelFormat == PixelFormat.Format8bppIndexed)
ColorPalette colorPalette = bitmap.Palette;
for (int i = 0; i < 256; i++)
colorPalette.Entries[i] = Color.FromArgb(i, i, i);
bitmap.Palette = colorPalette;
public static void UpdateBitmap(Bitmap bitmap, byte[] buffer, int width, int height, bool color)
if (!IsCompatible( bitmap, width, height, color))
throw new Exception("Cannot update incompatible bitmap.");
BitmapData bmpData = bitmap.LockBits(new Rectangle(0, 0, bitmap.Width, bitmap.Height), ImageLockMode.ReadWrite, bitmap.PixelFormat);
/* Get the pointer to the bitmap's buffer. */
IntPtr ptrBmp = bmpData.Scan0;
/* Compute the width of a line of the image data. */
int imageStride = GetStride(width, color);
/* If the widths in bytes are equal, copy in one go. */
if (imageStride == bmpData.Stride)
System.Runtime.InteropServices.Marshal.Copy(buffer, 0, ptrBmp, bmpData.Stride * bitmap.Height );
else /* The widths in bytes are not equal, copy line by line. This can happen if the image width is not divisible by four. */
for (int i = 0; i < bitmap.Height; ++i)
Marshal.Copy(buffer, i * imageStride, new IntPtr(ptrBmp.ToInt64() + i * bmpData.Stride), width);
/* Unlock the bits. */
bitmap.UnlockBits(bmpData);
