TA的每日心情 | 开心 2020-6-9 11:29 |
签到天数: 40 天 连续签到: 1 天 [LV.5]常住居民I
- 积分
- 193
- #include <iostream>
- #include <pcl/point_types.h>
- #include <pcl/PCLPointCloud2.h>
- #include <pcl/io/pcd_io.h>
- #include <pcl/io/ply_io.h>
- #include <QApplication>
- #include <QFileDialog>
- #include <QString>
- using namespace std;
- int main (int argc, char *argv[])
- QApplication a (argc, argv);
- pcl::PCDReader pcdreader;
- pcl::PCDWriter pcdwriter;
- pcl::PLYReader plyreader;
- pcl::PLYWriter plywriter;
- //QString q_filename = QFileDialog::getExistingDirectory(Q_NULLPTR,
- // "Select .pcd or .ply file",
- QString q_name = QFileDialog::getOpenFileName(Q_NULLPTR,
- "Select .pcd or .ply file",
- string name = q_name.toStdString();
- cout << "read: " << name << endl;
- int path_i = name.find_last_of("\")+1;
- int ext_i = name.find_last_of(".");
- string extname = name.substr(ext_i,name.size()-ext_i);
- string filename = name.substr(path_i,ext_i-path_i);
- pcl::PCLPointCloud2 cloud2;
- if(extname == ".pcd")
- int ret = pcdreader.read(name, cloud2);
- if (ret == -1) //* load the file
- PCL_ERROR ("Couldn't read pcd file \n");
- return (-1);
- plywriter.writeASCII(filename+".ply", cloud2);
- cout << "write: " << filename+".ply" << endl;
- else if(extname == ".ply")
- int ret = plyreader.read(name, cloud2);
- PCL_ERROR ("Couldn't read ply file \n");
- return (-1);
- pcdwriter.writeASCII(filename+".pcd", cloud2);
- cout << "write: " << filename+".pcd" << endl;
- else cout << "please choose .pcd or .ply file" << endl;
- return 0;
