TA的每日心情 | 开心 昨天 11:02 |
签到天数: 941 天 连续签到: 1 天 [LV.10]以坛为家III
- 积分
- 6562
- //缩放图像
- private void hWindowControl1_HMouseWheel(object sender, HMouseEventArgs e)
- HTuple Zoom, Row, Col, Button;
- HTuple Row0, Column0, Row00, Column00, Ht, Wt, r1, c1, r2, c2;
- if (e.Delta > 0)
- Zoom = 1.5;
- else
- Zoom = 0.5;
- HOperatorSet.GetMposition(WindowID, out Row, out Col, out Button);
- HOperatorSet.GetPart(WindowID, out Row0, out Column0, out Row00, out Column00);
- Ht = Row00 - Row0;
- Wt = Column00 - Column0;
- if (Ht * Wt < 32000 * 32000 || Zoom == 1.5)//普通版halcon能处理的图像最大尺寸是32K*32K。如果无限缩小原图像,导致显示的图像超出限制,则会造成程序崩溃
- r1 = (Row0 + ((1 - (1.0 / Zoom)) * (Row - Row0)));
- c1 = (Column0 + ((1 - (1.0 / Zoom)) * (Col - Column0)));
- r2 = r1 + (Ht / Zoom);
- c2 = c1 + (Wt / Zoom);
- HOperatorSet.SetPart(WindowID, r1, c1, r2, c2);
- HOperatorSet.ClearWindow(WindowID);
- HOperatorSet.DispObj(ho_image, WindowID);
- //鼠标按下,记录当前坐标值
- private void hWindowControl1_HMouseDown(object sender, HMouseEventArgs e)
- HTuple Row, Column, Button;
- HOperatorSet.GetMposition(WindowID, out Row, out Column, out Button);
- RowDown = Row; //鼠标按下时的行坐标
- ColDown = Column; //鼠标按下时的列坐标
- //鼠标抬起,实现图像移动
- private void hWindowControl1_HMouseUp(object sender, HMouseEventArgs e)
- HTuple row1, col1, row2, col2,Row, Column, Button;
- double RowMove = Row - RowDown; //鼠标弹起时的行坐标减去按下时的行坐标,得到行坐标的移动值
- double ColMove = Column - ColDown;//鼠标弹起时的列坐标减去按下时的列坐标,得到列坐标的移动值
- HOperatorSet.GetPart(WindowID, out row1, out col1, out row2, out col2);//得到当前的窗口坐标
- HOperatorSet.SetPart(WindowID, row1 - RowMove, col1 - ColMove, row2 - RowMove, col2 - ColMove);//这里可能有些不好理解。以左上角原点为参考点
- if (ImageHeight != null)
- else
- MessageBox.Show("请加载一张图片");
- //鼠标移动,实时显示当前坐标与灰度值
- private void hWindowControl1_HMouseMove(object sender, HMouseEventArgs e)
- HTuple Row, Column, Button, pointGray;
- HOperatorSet.GetMposition(WindowID, out Row, out Column, out Button); //获取当前鼠标的坐标值
- if (ImageHeight != null && (Row > 0 && Row < ImageHeight) && (Column > 0 && Column < ImageWidth))//设置3个条件项,防止程序崩溃。
- HOperatorSet.GetGrayval(ho_image, Row, Column, out pointGray); //获取当前点的灰度值
- else
- pointGray = "_";
- String str = String.Format("Row:{0} Column:{1} Gray:{2}", Row, Column, pointGray); //格式化字符串
- label1.Text = str; //在label控件上显示数值
- //全屏显示图像,使缩放后的图像回到原始大小
- private void button_FullWindow_Click(object sender, EventArgs e)
- HOperatorSet.SetPart(WindowID, 0, 0, ImageHeight - 1, ImageWidth - 1);
网上找的代码,说实话上面这个代码是一般般,建议把再添加一个控件的MOVE方法,可以实现滚轮缩放,按住鼠标移动就拖拽,不像上面这个代码一样一卡一卡再显示!
出现闪烁的话,在ClearWindow之前设置
- HOperatorSet.SetSystem("flush_graphic", "false");
清除窗口后再重新打开
- HOperatorSet.SetSystem("flush_graphic", "true");
