TA的每日心情 | 衰 2020-8-17 15:49 |
签到天数: 17 天 连续签到: 1 天 [LV.4]偶尔看看III
- 积分
- 59
百度了很久,还是不懂,有大佬帮我解释下么,创建模型的时候这些算子的参数数据怎么获得的。大体思路是?
set_system ('border_shape_models', 'false')
set_system ('int_zooming', 'true')
set_system('clip_region','false')
dev_close_window ()
dev_update_off ()
dev_open_window (0, 0, 640, 480, 'black', WindowHandle)
dev_set_draw ('margin')
set_display_font (WindowHandle, 16, 'mono', 'true', 'false')
dev_set_line_width (2)
dev_set_color ('green')
AmplitudeThreshold := 12
* 创建模板
if(false)
//读取图片
read_image (Image, 'Model.bmp')
//创建矩形模板
gen_rectangle2 (ModelRegion, 1046.55, 502.87, rad(10.9339), 178.542, 81.8375)
//减少图片的范围
reduce_domain (Image, ModelRegion, TemplateImage)
//创建一个匹配的模型
create_shape_model (TemplateImage, 5, rad(0), rad(360), rad(0.6245), ['none','no_pregeneration'], 'use_polarity', [15,30,50], 4, ModelID)
//返回形状模型
get_shape_model_contours (ModelContours, ModelID, 1)
//区域面积和中心
area_center (ModelRegion, ModelRegionArea, RefRow, RefColumn)
//从点和角度计算刚性仿射变换。
vector_angle_to_rigid (0, 0, 0, RefRow, RefColumn, 0, HomMat2D)
//对XLD轮廓应用任意仿射2D变换。
affine_trans_contour_xld (ModelContours, TransContours, HomMat2D)
//在“图像”中找到形状模型的最佳匹配。
find_shape_model (Image, ModelID, rad(0), rad(360), 0.51, 1, 0.5, 'least_squares', [5,1], 0.75, ModelRow, ModelColumn, ModelAngle, Score)
//将形状模型写入文件。
write_shape_model (ModelID, './ModelID')
//显示
dev_display (Image)
dev_display (ModelRegion)
dev_display (TransContours)
* Rectangle0
TmpCtrl_Row := 926
TmpCtrl_Column := 1074
TmpCtrl_Phi := -1.35726
TmpCtrl_Len1 := 100
TmpCtrl_Len2 := 10
//创建一个任意方向的矩形。
gen_rectangle2 (Rectangle0, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
//将区域写入文件
write_region (Rectangle0, 'Rectangle0.hobj')
* Rectangle1
TmpCtrl_Row := 847.673
TmpCtrl_Column := 1425.64
TmpCtrl_Phi := -1.36127
TmpCtrl_Len1 := 70
TmpCtrl_Len2 := 10
gen_rectangle2 (Rectangle1_1, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
write_region (Rectangle1_1, 'Rectangle1_1.hobj')
TmpCtrl_Row := 1038
TmpCtrl_Column := 554
TmpCtrl_Len1 := 70
TmpCtrl_Len2 := 10
gen_rectangle2 (Rectangle1_2, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
write_region (Rectangle1_2, 'Rectangle1_2.hobj')
* Rectangle2
TmpCtrl_Row := 987.028
TmpCtrl_Column := 1061.99
TmpCtrl_Phi := 0.214
TmpCtrl_Len1 := 374
TmpCtrl_Len2 := 10
gen_rectangle2 (Rectangle2, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
write_region (Rectangle2, 'Rectangle2.hobj')
* Rectangle3
TmpCtrl_Row := 874.972
TmpCtrl_Column := 1038.08
TmpCtrl_Len1 := 374
TmpCtrl_Len2 := 10
gen_rectangle2 (Rectangle3, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
write_region (Rectangle3, 'Rectangle3.hobj')
* Rectangle4
TmpCtrl_Row := 959.71
TmpCtrl_Column := 918.038
TmpCtrl_Phi := 0.217258
TmpCtrl_Len1 := 616.136
TmpCtrl_Len2 := 10
gen_rectangle2 (Rectangle4, TmpCtrl_Row, TmpCtrl_Column, TmpCtrl_Phi, TmpCtrl_Len1, TmpCtrl_Len2)
write_region (Rectangle4, 'Rectangle4.hobj')
* Rectangle5 检测区域
gen_rectangle2 (Rectangle5_1, 994.108, 760.656, 1.78017, 75, 38)
gen_rectangle2 (Rectangle5_2, 963.114, 904.277, 1.78017, 75, 38)
write_region (Rectangle5_1, 'Rectangle5_1.hobj')
write_region (Rectangle5_2, 'Rectangle5_2.hobj')
stop ()
endif |
