查看: 1942|回复: 4
[待解决] 【难点】 求大神解决,如何找出凹痕
    2019-12-17 12:56
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    26
    99
    发表于 2021-5-12 10:48:00 | 显示全部楼层 |阅读模式
    求大神解决,如何找出凹痕。
    凹痕缺陷
    凹痕缺陷
    19
    31
    发表于 2021-5-28 08:22:48 | 显示全部楼层
    建议深度学习AI
    2020-9-22 18:10
  • 签到天数: 2 天
    24
    40
    发表于 2021-6-1 13:55:38 | 显示全部楼层
    这个暂时没有试到合适的办法呀,楼主解决了的话分享一下思路哈
    慵懒
    2022-3-25 13:51
  • 签到天数: 52 天
    28
    115
    发表于 2021-6-10 17:40:01 | 显示全部楼层
    read_image (Image002, 'G:/learning_halcon_file/img/002.png')
    decompose3(Image002, R, G, B)
    trans_from_rgb(R, G, B, H, S, V, 'hsv')
    binary_threshold(H, Region1, 'max_separability', 'light', UsedThreshold)
    connection(Region1, ConnectedRegions1)
    select_shape(ConnectedRegions1, SelectedRegions1, 'area', 'and', 100000, 999999)
    binary_threshold(V, Region2, 'max_separability', 'light', UsedThreshold)
    connection(Region2, ConnectedRegions2)
    select_shape(ConnectedRegions2, SelectedRegions2, 'area', 'and', 250000, 999999)
    intersection(SelectedRegions1, SelectedRegions2, RegionIntersection)
    reduce_domain(S, RegionIntersection, ImageReduced)
    fill_up(RegionIntersection, RegionFillUp)
    opening_circle(RegionFillUp, RegionOpening, 5.5)
    shape_trans(RegionOpening, RegionTrans, 'convex')
    reduce_domain(S, RegionTrans, ImageReduced1)
    * emphasize(ImageReduced1, ImageEmphasize, 7, 7, 20)
    median_image(ImageReduced1, ImageMedian, 'circle', 3, 'mirrored')
    scale_image_max(ImageMedian, ImageScaleMax)
    threshold (ImageScaleMax, Regions, 97, 211)
    fill_up(Regions, RegionFillUp1)
    opening_circle(RegionFillUp1, RegionOpening1, 5.5)
    clip_region_rel(RegionOpening1, RegionClipped, 2, 2, 8, 25)
    reduce_domain(B, RegionClipped, ImageReduced2)
    median_image(ImageReduced2, ImageMedian2, 'circle', 3, 'mirrored')
    emphasize(ImageMedian2, ImageEmphasize1, 5, 5, 10)
    median_image(ImageEmphasize1, ImageMedian1, 'circle', 2, 'mirrored')
    emphasize(ImageMedian1, ImageEmphasize2, 7, 7, 1)
    edges_sub_pix(ImageReduced2, Edges, 'canny', 1, 8, 15)
    * union_collinear_contours_xld(Edges, UnionContours1, 20, 1, 2, 0.1, 'attr_keep')
    union_adjacent_contours_xld(Edges, UnionContours, 20, 5, 'attr_keep')
    select_contours_xld(Edges, SelectedContours, 'contour_length', 10, 200, -0.5, 0.5)
    union_adjacent_contours_xld(SelectedContours, UnionContours2, 10, 1, 'attr_keep')
    select_contours_xld(UnionContours2, SelectedContours1, 'contour_length', 15, 200, -0.5, 0.5)
    close_contours_xld(SelectedContours1, ClosedContours)
    shape_trans_xld(ClosedContours, XLDTrans, 'rectangle1')
    gen_region_contour_xld(XLDTrans, Region, 'filled')
    erosion_rectangle1(Region, RegionErosion, 3, 3)
    dev_set_draw ('margin')
    dev_display(Image002)
    dev_display(RegionErosion)
    慵懒
    2022-3-25 13:51
  • 签到天数: 52 天
    28
    115
    发表于 2021-6-10 18:16:25 | 显示全部楼层
