查看: 1342|回复: 4
[软件错误] set_dl_model_param算子报错
    2022-1-6 09:11
  • 签到天数: 14 天
    4
    39
    155
    发表于 2021-5-22 22:47:40 | 显示全部楼层 |阅读模式
    在halcon20中可以正常运行,导入C#代码后会报错。大家有遇到过这种情况吗?
    半小时前
  • 签到天数: 1436 天
    连续签到: 40 天
    428
    1816
    7464
    发表于 2021-5-24 12:03:25 | 显示全部楼层
    get_dl_model_param 查下支持cpu不! 设置下runtime_init为cpu呢?
    2022-1-6 09:11
  • 签到天数: 14 天
    4
    39
    155
     楼主| 发表于 2021-5-26 10:37:28 | 显示全部楼层
    get_dl_model_param 可以支持cpu,如图所示。runtime_init设置cpu在halcon就会报错。很奇怪的是,set_dl_model_param (DLModelHandle, 'runtime', 'cpu')在halcon中运行就不会报错,而导出C#引用halcondotnet.dll,运行到     HOperatorSet.SetDlModelParam(hv_DLModelHandle, "runtime", "cpu");就报错了。
    在halcon中x64-win64文件夹下有halcondl.dll,hcanvas.dll深度学习的库,是否也需要引用,但是这些都是C++d的库,在dotnet35文件夹中没有。
    get_dl_model_param
    get_dl_model_param
    runtime_init
    runtime_init
    2022-5-20 13:06
  • 签到天数: 33 天
    18
    97
    175
    发表于 2021-5-28 13:53:26 | 显示全部楼层
    Hi, 17512008836!
    I have the same problem with 'cpu'. Hope you will got the solution.
    And also sometimes I had the problem with code:
    HOperatorSet.SetDlClassifierParam(DL, "runtime_init", "immediately");
    I am used «Compact.hdl» for training.
    2022-5-20 13:06
  • 签到天数: 33 天
    18
    97
    175
    发表于 2021-5-28 13:57:54 | 显示全部楼层
    And also I had problem with code:
    HOperatorSet.SetDlClassifierParam(DL, "runtime", "gpu");
    when 'gpu' already was setted.
    Why it is happens - I don't understand.
    I do the check of this parameter before setting.
