查看: 763|回复: 7
[软件需求] Fast method to convert HObjecrt to Bitmap
    6 天前
  • 签到天数: 33 天
    18
    97
    175
    发表于 2021-6-10 19:21:07 | 显示全部楼层 |阅读模式
    Hi, colleagues!
    Can anyone help to understand: is any simple and very fast method to convert Image as HObject to Bitmap???
    Image size 3000x3000 converting for 1500 ms - it is bad!!!!!
    I am using this code:
            public static Bitmap HObject2ColoredBitmap(this HObject myHObject)
                Stopwatch sw = new Stopwatch();
                sw.Start();
                HTuple pointerRed = null;
                HTuple pointerGreen = null;
                HTuple pointerBlue = null;
                HTuple type;
                HTuple width;
                HTuple height;
                HOperatorSet.GetImagePointer3(myHObject, out pointerRed, out pointerGreen, out pointerBlue, out type, out width, out height);
                if (width.Type == HTupleType.EMPTY || height.Type == HTupleType.EMPTY)
                    return null;
                Bitmap bitmap = new Bitmap((Int32)width, (Int32)height, System.Drawing.Imaging.PixelFormat.Format32bppRgb);
                BitmapData bmpData = bitmap.LockBits(new Rectangle(0, 0, bitmap.Width / 4, bitmap.Height / 4), ImageLockMode.ReadWrite, bitmap.PixelFormat);
                IntPtr source_scan = bmpData.Scan0;
                unsafe
                    byte* source_p = (byte*)source_scan.ToPointer();
                    byte* Red = (byte*)pointerRed.IP.ToPointer();
                    byte* Blue = (byte*)pointerBlue.IP.ToPointer();
                    byte* Green = (byte*)pointerGreen.IP.ToPointer();
                    for (int h = 0; h < bitmap.Height; h++)
                        for (int w = 0; w < bitmap.Width; w++)
                            source_p[0] = Blue[0];  //A
                            source_p++;
                            Blue++;
                            source_p[0] = Green[0];  //R
                            source_p++;
                            Green++;
                            source_p[0] = Red[0];  //G
                            source_p++;
                            Red++;
                            source_p++;
                bitmap.UnlockBits(bmpData);
                sw.Stop();
                Console.WriteLine($"Преобразование HObject в Bitmap: {sw.ElapsedMilliseconds}");
                sw = null;
                GC.Collect();
                return bitmap;
    昨天 17:13
  • 签到天数: 78 天
    [LV.6]常住居民II
    46
    175
    发表于 2021-6-10 20:29:59 | 显示全部楼层
    1. private static void HObject2ColoredBitmap(HObject image, out Bitmap res)
    2.         {
    3.             try
    4.             {
    5.                 HTuple hred, hgreen, hblue, type, width, height;
    6.                 HOperatorSet.GetImagePointer3(image, out hred, out hgreen, out hblue, out type, out width, out height);
    7.                 res = new Bitmap(width, height, System.Drawing.Imaging.PixelFormat.Format32bppRgb);
    8.                 Rectangle rect = new Rectangle(0, 0, width, height);
    9.                 BitmapData bitmapData = res.LockBits(rect, ImageLockMode.ReadWrite, PixelFormat.Format32bppRgb);
    10.                 int imglength = width * height;
    11.                 unsafe
    12.                 {
    13.                     byte* bptr = (byte*)bitmapData.Scan0;
    14.                     byte* r = ((byte*)hred.I);      //((byte*)hred.L);
    15.                     byte* g = ((byte*)hgreen.I);    // ((byte*)hgreen.L);
    16.                     byte* b = ((byte*)hblue.I);     //((byte*)hblue.L);
    17.                     for (int i = 0; i < imglength; i++)
    18.                     {
    19.                         bptr[i * 4] = (b)[i];
    20.                         bptr[i * 4 + 1] = (g)[i];
    21.                         bptr[i * 4 + 2] = (r)[i];
    22.                         bptr[i * 4 + 3] = 255;
    23.                     }
    24.                 }
    25.                 res.UnlockBits(bitmapData);
    26.             }
    27.             catch (Exception ex)
    28.             {
    29.                 res = null;
    30.                 throw ex;
    31.             }
    32.         }
    6 天前
  • 签到天数: 33 天
    18
    97
    175
     楼主| 发表于 2021-6-15 19:59:25 | 显示全部楼层
    Thank you for answer!
    6 天前
  • 签到天数: 33 天
    18
    97
    175
     楼主| 发表于 2021-6-15 20:01:44 | 显示全部楼层
    Unfourtanely this code is not working.
    Checked.
    昨天 10:36
  • 签到天数: 1432 天
    连续签到: 36 天
    428
    1816
    7443
    发表于 2021-6-19 20:09:11 | 显示全部楼层
    Checked.
    it's helpfull for you:https://www.51halcon.com/forum.p ... &tid=4778&fromuid=3
    6 天前
  • 签到天数: 33 天
    18
    97
    175
     楼主| 发表于 2021-6-29 18:11:09 | 显示全部楼层
    Hi, Criss )
    Thank you for your help.
    Is only one problem: I can't download attached project file from Baidu vault.
    Is any possibility to download this example with another way?
    6 天前
  • 签到天数: 33 天
    18
    97
    175
     楼主| 发表于 2021-6-29 18:14:59 | 显示全部楼层
    Hi, Criss )))
    https://1drv.ms/u/s!AgtcKzAtnq7fi0Ae4NwpPOrCQPM9?e=FezI1m
    Thank you very much!!!
    I will send you feedback when I will understand this example )
    昨天 10:36
  • 签到天数: 1432 天
    连续签到: 36 天
    428
    1816
    7443
    发表于 2021-7-2 16:24:52 | 显示全部楼层
    Evgeniy 发表于 2021-6-29 18:14
    Hi, Criss )))
    you're welcome!
