查看: 1222|回复: 7
[软件错误] disp_message 参数数量错误
6
11
发表于 2021-6-21 17:07:46 | 显示全部楼层 |阅读模式
* This procedure displays text in a graphics window.
* Input parameters:
* WindowHandle: The WindowHandle of the graphics window, where
*    the message should be displayed.
* String: A tuple of strings containing the text messages to be displayed.
* CoordSystem: If set to 'window', the text position is given
*    with respect to the window coordinate system.
*    If set to 'image', image coordinates are used.
*    (This may be useful in zoomed images.)
* Row: The row coordinate of the desired text position.
*    You can pass a single value or a tuple of values.
*    See the explanation below.
*    Default: 12.
* Column: The column coordinate of the desired text position.
*    Default: 12.
* Color: defines the color of the text as string.
*    If set to [] or '' the currently set color is used.
*    If a tuple of strings is passed, the colors are used cyclically
*    for every text position defined by Row and Column,
*    or every new text line in case of |Row| == |Column| == 1.
* Box: A tuple controlling a possible box surrounding the text.
*    Its entries:
*    - Box[0]: Controls the box and its color. Possible values:
*      -- 'true' (Default): An orange box is displayed.
*      -- 'false': No box is displayed.
*      -- color string: A box is displayed in the given color, e.g., 'white', '#FF00CC'.
*    - Box[1] (Optional): Controls the shadow of the box. Possible values:
*      -- 'true' (Default): A shadow is displayed in
*                darker orange if Box[0] is not a color and in 'white' otherwise.
*      -- 'false': No shadow is displayed.
*      -- color string: A shadow is displayed in the given color, e.g., 'white', '#FF00CC'.
* It is possible to display multiple text strings in a single call.
* In this case, some restrictions apply on the
* parameters String, Row, and Column:
* They can only have either 1 entry or n entries.
* Behavior in the different cases:
*    - Multiple text positions are specified, i.e.,
*        - |Row| == n, |Column| == n
*        - |Row| == n, |Column| == 1
*        - |Row| == 1, |Column| == n
*      In this case we distinguish:
*        - |String| == n: Each element of String is displayed
*                         at the corresponding position.
*        - |String| == 1: String is displayed n times
*                         at the corresponding positions.
*    - Exactly one text position is specified,
*       i.e., |Row| == |Column| == 1:
*       Each element of String is display in a new textline.
* Convert the parameters for disp_text.
if (Row == [] or Column == [])
    return ()
endif
if (Row == -1)
    Row := 12
endif
if (Column == -1)
    Column := 12
endif
* Convert the parameter Box to generic parameters.
GenParamName := []
GenParamValue := []
if (|Box| > 0)
    if (Box[0] == 'false')
        * Display no box
        GenParamName := [GenParamName,'box']
        GenParamValue := [GenParamValue,'false']
    elseif (Box[0] != 'true')
        * Set a color other than the default.
        GenParamName := [GenParamName,'box_color']
        GenParamValue := [GenParamValue,Box[0]]
    endif
endif
if (|Box| > 1)
    if (Box[1] == 'false')
        * Display no shadow.
        GenParamName := [GenParamName,'shadow']
    elseif (Box[1] != 'true')
        * Set a shadow color other than the default.
        GenParamName := [GenParamName,'shadow_color']
        GenParamValue := [GenParamValue,Box[1]]
    endif
endif
* Restore default CoordSystem behavior.
if (CoordSystem != 'window')
    CoordSystem := 'image'
endif
if (Color == '')
    * disp_text does not accept an empty string for Color.
    Color := []
endif
disp_message (WindowHandle, String, CoordSystem, Row, Column, Color, GenParamName, GenParamValue)
return ()
在函数disp_message的101行有无效代码行
disp_message (
: : WindowHandle, String, CoordSystem, Row, Column, Color, Box : )
外部函数:
This procedure writes one or multiple text messages.
D:/software/Halcon/programs/HALCON-21.05-Progress/procedures/general/disp_message.hdvp
错误: '参数数量错误' [21207] 位置; 13 到 96
错误的标记
您是否希望继续程序或编辑错误代码行?
    1 小时前
  • 签到天数: 942 天
    224
    1035
    6569
    发表于 2021-6-21 19:36:10 | 显示全部楼层
    检查下参数表参数数量:
    disp_message( : : WindowHandle, String, CoordSystem, Row, Column, Color, Box : )
    6
    11
     楼主| 发表于 2021-6-21 20:38:23 | 显示全部楼层
    绝地武士 发表于 2021-6-21 19:36
    检查下参数表参数数量:
    disp_message( : : WindowHandle, String, CoordSystem, Row, Column, Color, Box  ...
    disp_message (WindowID, '面积'+Area+'坐标:'+Row+' '+Column,'window',0,0, 'white', 'false')
    上面的是一个列子的,
    所有程序跑起来都错误
    是不是和版本有关系?我用的是21.05版本
    1 小时前
  • 签到天数: 942 天
    224
    1035
    6569
    发表于 2021-6-21 21:32:34 | 显示全部楼层
    上面的 ...
    没有任何问题呢?这代码随便怎么都可以过去!
    1. dev_get_window (WindowID)
    2. read_image (Image, 'printer_chip/printer_chip_01')
    3. Area:=520
    4. Row:=200
    5. Column:=200
    6. disp_message (WindowID, '面积'+Area+'坐标:'+Row+' '+Column,'window',0,0, 'white', 'false')
    6
    11
     楼主| 发表于 2021-6-21 22:13:35 | 显示全部楼层
    disp_message ( : : WindowHandle, String, CoordSystem, Row, Column, Color, Box : )
    外部函数:
    您是否希望继续程序或编辑错误代码行?
    我用你的程序跑,上面的这条错误还在。我跑含有disp_messaged()例程时,也会出错。
    6
    11
     楼主| 发表于 2021-6-21 22:16:48 | 显示全部楼层
    disp_message ( : : WindowHandle, String, CoordSystem, Row, C ...
    1. ////这是主程序
    2. * Image Acquisition 02: Code generated by Image Acquisition 02
    3. open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', 8, 'rgb', -1, 'false', 'default', '[0] USB2.0 VGA UVC WebCam', 0, -1, AcqHandle)
    4. grab_image_start (AcqHandle, -1)
    5. dev_close_window()
    6. dev_open_window(0,0,728,512,'black',WindowID)
    7. while (true)
    8.     grab_image_async (Image, AcqHandle, -1)
    9.     * Image Acquisition 02: Do something
    10.     rgb1_to_gray (Image, GrayImage)
    11.     dev_display (GrayImage)
    12.     threshold (GrayImage, Regions, 82, 255)
    13.     connection (Regions, ConnectedRegions)
    14.
    15.     select_shape (ConnectedRegions, SelectedRegions, 'area', 'and', 21951.2, 200000)
    16.     dev_display (GrayImage)
    17.     dev_display (SelectedRegions)
    18.     area_center (SelectedRegions, Area, Row, Column)
    19.     disp_message (WindowID, '面积'+Area+'坐标:'+Row+' '+Column,'window',0,0, 'white', 'false')
    20.
    21. endwhile
    22. close_framegrabber (AcqHandle)
    23. ////这是disp_message()
    24. * This procedure displays text in a graphics window.
    25. *
    26. * Input parameters:
    27. * WindowHandle: The WindowHandle of the graphics window, where
    28. *    the message should be displayed.
    29. * String: A tuple of strings containing the text messages to be displayed.
    30. * CoordSystem: If set to 'window', the text position is given
    31. *    with respect to the window coordinate system.
    32. *    If set to 'image', image coordinates are used.
    33. *    (This may be useful in zoomed images.)
    34. * Row: The row coordinate of the desired text position.
    35. *    You can pass a single value or a tuple of values.
    36. *    See the explanation below.
    37. *    Default: 12.
    38. * Column: The column coordinate of the desired text position.
    39. *    You can pass a single value or a tuple of values.
    40. *    See the explanation below.
    41. *    Default: 12.
    42. * Color: defines the color of the text as string.
    43. *    If set to [] or '' the currently set color is used.
    44. *    If a tuple of strings is passed, the colors are used cyclically
    45. *    for every text position defined by Row and Column,
    46. *    or every new text line in case of |Row| == |Column| == 1.
    47. * Box: A tuple controlling a possible box surrounding the text.
    48. *    Its entries:
    49. *    - Box[0]: Controls the box and its color. Possible values:
    50. *      -- 'true' (Default): An orange box is displayed.
    51. *      -- 'false': No box is displayed.
    52. *      -- color string: A box is displayed in the given color, e.g., 'white', '#FF00CC'.
    53. *    - Box[1] (Optional): Controls the shadow of the box. Possible values:
    54. *      -- 'true' (Default): A shadow is displayed in
    55. *                darker orange if Box[0] is not a color and in 'white' otherwise.
    56. *      -- 'false': No shadow is displayed.
    57. *      -- color string: A shadow is displayed in the given color, e.g., 'white', '#FF00CC'.
    58. *
    59. * It is possible to display multiple text strings in a single call.
    60. * In this case, some restrictions apply on the
    61. * parameters String, Row, and Column:
    62. * They can only have either 1 entry or n entries.
    63. * Behavior in the different cases:
    64. *    - Multiple text positions are specified, i.e.,
    65. *        - |Row| == n, |Column| == n
    66. *        - |Row| == n, |Column| == 1
    67. *        - |Row| == 1, |Column| == n
    68. *      In this case we distinguish:
    69. *        - |String| == n: Each element of String is displayed
    70. *                         at the corresponding position.
    71. *        - |String| == 1: String is displayed n times
    72. *                         at the corresponding positions.
    73. *    - Exactly one text position is specified,
    74. *       i.e., |Row| == |Column| == 1:
    75. *       Each element of String is display in a new textline.
    76. *
    77. *
    78. * Convert the parameters for disp_text.
    79. if (Row == [] or Column == [])
    80.     return ()
    81. endif
    82. if (Row == -1)
    83.     Row := 12
    84. endif
    85. if (Column == -1)
    86.     Column := 12
    87. endif
    88. *
    89. * Convert the parameter Box to generic parameters.
    90. GenParamName := []
    91. GenParamValue := []
    92. if (|Box| > 0)
    93.     if (Box[0] == 'false')
    94.         * Display no box
    95.         GenParamName := [GenParamName,'box']
    96.         GenParamValue := [GenParamValue,'false']
    97.     elseif (Box[0] != 'true')
    98.         * Set a color other than the default.
    99.         GenParamName := [GenParamName,'box_color']
    100.         GenParamValue := [GenParamValue,Box[0]]
    101.     endif
    102. endif
    103. if (|Box| > 1)
    104.     if (Box[1] == 'false')
    105.         * Display no shadow.
    106.         GenParamName := [GenParamName,'shadow']
    107.         GenParamValue := [GenParamValue,'false']
    108.     elseif (Box[1] != 'true')
    109.         * Set a shadow color other than the default.
    110.         GenParamName := [GenParamName,'shadow_color']
    111.         GenParamValue := [GenParamValue,Box[1]]
    112.     endif
    113. endif
    114. * Restore default CoordSystem behavior.
    115. if (CoordSystem != 'window')
    116.     CoordSystem := 'image'
    117. endif
    118. *
    119. if (Color == '')
    120.     * disp_text does not accept an empty string for Color.
    121.     Color := []
    122. endif
    123. *
    124. disp_message (WindowHandle, String, CoordSystem, Row, Column, Color, GenParamName, GenParamValue)
    125. return ()
    1 小时前
  • 签到天数: 942 天
    224
    1035
    6569
    发表于 2021-6-22 09:55:13 | 显示全部楼层
    101行是disp_text函数,你是不是手误替换了函数导致异常了?附件给你,自行替换吧
    disp_message.rar (3.07 KB, 下载次数: 14)
    6
    11
     楼主| 发表于 2021-6-22 10:58:46 | 显示全部楼层
    感谢大佬,问题解决了
