查看: 726|回复: 3
[未解决] 如何把明显不是钉子的显示去除掉
    2021-8-21 20:28
  • 签到天数: 2 天
    8
    31
    64
    发表于 2021-8-18 16:35:40 | 显示全部楼层 |阅读模式
    在我们的一个项目中,需要对客户的地板上的钉子找到,halcon程序写了2版,应该说比以前好了很多i,但是还是把其他不是钉子的地方找出来,由于客户地板上的钉子是机器打的,所以基本保持相同的横向和纵向距离,所以如何在代码中在最后加上这个距离的判断,使明显不对的钉子不要显示出来。代码如下所示,请查看:
    1. * 识别区域
    2. gen_rectangle1 (Rectangle, startY, startX, EndY, EndX)
    3. reduce_domain (Image, Rectangle, ImageReduced)
    4. * 初步边缘提取
    5. edges_image (ImageReduced, ImaAmp, ImaDir, 'canny', 1, 'nms', 10, 20)
    6. threshold (ImaAmp, Region1, 1, 255)
    7. connection (Region1, ConnectedRegions)
    8. select_shape (ConnectedRegions, SelectedRegions, ['outer_radius','anisometry','area'], 'and', [10,1,50], [30,3.9,300])
    9. shape_trans (SelectedRegions, RegionTrans, 'outer_circle')
    10. dilation_circle (RegionTrans, RegionDilation,5.5)
    11. union1 (RegionDilation, RegionUnion)
    12. reduce_domain (Image, RegionUnion, ImageReduced2)
    13. * 详细边缘提取
    14. edges_sub_pix (ImageReduced2, Edges, 'canny', 1, 5, 15)
    15. select_shape_xld (Edges, SelectedXLD, ['contlength','outer_radius'], 'and', [28,10], [99999,99999])
    16. segment_contours_xld (SelectedXLD, ContoursSplit, 'lines_circles', 4, 2, 2)
    17. * 筛选
    18. count_obj (ContoursSplit, NumberContours)
    19. gen_empty_obj (Circles)
    20. for i := 1 to NumberContours by 1
    21.     select_obj (ContoursSplit, ObjectSelected, i)
    22.     get_contour_global_attrib_xld (ObjectSelected, 'cont_approx', Attrib)
    23.     if (Attrib == 1)
    24.         concat_obj (Circles, ObjectSelected, Circles)
    25.     endif
    26. endfor
    27. union_cocircular_contours_xld (Circles, UnionContours2, rad(60), rad(10), rad(30), 100, 50, 10, 'true', 1)
    28. select_contours_xld (UnionContours2, SelectedContours, 'contour_length', 28, 200, -0.5, 0.5)
    29. * 拟合圆
    30. count_obj (SelectedContours, NumberCircles)
    31. gen_empty_obj (ContCircles)
    32. for i := 1 to NumberCircles by 1
    33.     select_obj (SelectedContours, ObjectSelected, i)
    34.     fit_circle_contour_xld (ObjectSelected, 'algebraic', -1, 0, 0, 3, 2, Row, Column, Radius, StartPhi, EndPhi, PointOrder)
    35.     gen_circle_contour_xld (ContCircle, Row, Column, Radius, 0, rad(360), 'positive', 1.5)
    36.     GetRow[i-1] := Row
    37.     GetCol[i-1] := Column
    38.     concat_obj (ContCircles, ContCircle, ContCircles)
    39. endfor
    40. * 排序
    41. sort_contours_xld (ContCircles, SortedContours, 'upper_left', 'true', 'row')
    42. ResultRow := []
    43. ResultCol := []
    44. SampleRow := []
    45. SampleCol := []
    46. count_obj (SortedContours, Number2)
    47. j:=0
    48. if (Number2 >= 2)
    49.     n := 1
    50.     for i := 2 to Number2 by 1
    51.         select_obj (SortedContours, Circle1, i-1)
    52.         area_center_xld (Circle1, Area1, Row1, Column1, PointOrder1)
    53.         select_obj (SortedContours, Circle2, i)
    54.         area_center_xld (Circle2, Area2, Row2, Column2, PointOrder2)
    55.         distance_pp(Row1, Column1, Row2, Column2, Distance)
    56.        * disp_line(PointOrder2, Row1, Column1, Row2, Column2)
    57.         if (i == 2)
    58.             ResultRow[0] := Row1
    59.             ResultCol[0] := Column1
    60.         endif
    61.         if (Distance > 10)
    62.             ResultRow[n] := Row2
    63.             ResultCol[n] := Column2
    64.             n := n+1
    65.         endif
    66.         j:=j+1
    67.     endfor
    68. endif
    69. return ()
    2021-8-21 20:28
  • 签到天数: 2 天
    8
    31
    64
     楼主| 发表于 2021-8-18 16:48:52 | 显示全部楼层
    无聊
    3 小时前
  • 签到天数: 108 天
    [LV.6]常住居民II
    21
    155
    发表于 2021-8-25 08:50:42 | 显示全部楼层
    可以尝试,先按中心点row排序,然后按照两两column相减在某个范围筛选,
    2021-8-21 20:28
  • 签到天数: 2 天
    8
    31
    64
     楼主| 发表于 2021-8-31 17:26:52 | 显示全部楼层
    谢谢你的回复,我再看一下
