查看: 371|回复: 2
[待解决] How to break continuous grabbing from the camera?
    2022-4-27 12:08
  • 签到天数: 32 天
    18
    97
    174
    发表于 2021-11-22 17:02:33 | 显示全部楼层 |阅读模式
    Hi, colleagues.
    I am working with my web camera. And I start grabbing from this camera. But I do it like that:
    dev_open_window(0, 0, 640, 480, 'black', WindowHandle)
    open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', \
                       8, 'rgb', -1, 'false', 'default', \
                       '[0] Logitech HD Webcam C270', 0, -1, AcqHandle)
    status:=true
    while (status)
        grab_image (Image, AcqHandle)
        * Do something
        dev_display(Image)
    endwhile
    close_framegrabber (AcqHandle)
    I I need to press any key  for quit from 'while' code.
    I just want to know: is it possible to stop 'while' the code with key pressing?
    Can you help me?
    昨天 09:52
  • 签到天数: 939 天
    连续签到: 3 天
    224
    1035
    6547
    发表于 2021-11-22 17:45:02 | 显示全部楼层
    1. get_mbutton — Wait until a mouse button is pressed.
    2. 1: Left button,
    3. 2: Middle button,
    4. 4: Right button,
    5. 8: Shift key,
    6. 16: Ctrl key,
    7. 32: Alt key.
    It will cause blockage.
    or use serial communication, send some chars to terminated it from other program (use open_serial.)
    simulation software:https://www.51halcon.com/forum.p ... &tid=289&fromuid=25
    2022-4-27 12:08
  • 签到天数: 32 天
    18
    97
    174
     楼主| 发表于 2021-11-25 02:16:31 | 显示全部楼层
    Hi, Jedi Knight!
    Thank you for your answer.
    But I need the solution without freezing the process )))
