查看: 2679|回复: 2
[待解决] Image对齐
6
473
发表于 2017-3-18 16:33:10 | 显示全部楼层 |阅读模式
请教一下:两幅图片方位已经校正,并且已经计算出Image的XLD中心点,只需进行平移操作,如何平移其中一幅图像使两张Image对齐重合
    2 小时前
  • 签到天数: 951 天
    连续签到: 11 天
    378
    1547
    7258
    发表于 2017-3-20 17:11:55 | 显示全部楼层
    RE: Image对齐
    1. set_system ('border_shape_models', 'true')
    2. HeightInc:=200
    3. WidthInc:=400
    4. read_image (Image1, '1.bmp')
    5. read_image (Image2, '2.bmp')
    6. copy_image(Image1, Image11)
    7. copy_image(Image2, Image22)
    8. gen_empty_obj(Image1)
    9. get_image_size(Image11, Width, Height)
    10. gen_image_const(ImageBlack, 'byte', Width, Height)
    11. append_channel (Image1, Image11, Image1)
    12. append_channel (Image1, ImageBlack, Image1)
    13. tile_channels (Image1, TiledImage1, 2, 'horizontal')
    14. gen_rectangle1 (Rectangle1, HeightInc, Width-WidthInc-10, Height-HeightInc, Width-10)
    15. reduce_domain(TiledImage1, Rectangle1, ImageReduced)
    16. create_aniso_shape_model (ImageReduced, 'auto', -0.39, 0.79, 'auto', 0.95, 1.05, 'auto', 0.95, 1.05, 'auto', 'auto', 'use_polarity', 'auto', 'auto', ModelID)
    17. get_shape_model_contours (ModelContours, ModelID, 1)
    18. find_aniso_shape_model (ImageReduced, ModelID, -0.39, 0.78, 0.95, 1.05, 0.95, 1.05, 0.5, 1, 0.5, 'least_squares', 0, 0.9, Row1, Column1, Angle1, ScaleR1, ScaleC1, Score1)
    19. dev_display_shape_matching_results (ModelID, 'green', Row1, Column1, Angle1, ScaleR1, ScaleC1, 0)
    20. gen_empty_obj(Image2)
    21. append_channel (Image2, ImageBlack, Image2)
    22. append_channel (Image2, Image22, Image2)
    23. tile_channels (Image2, TiledImage2, 2, 'horizontal')
    24. gen_rectangle1 (ROI, HeightInc, Width, Height-HeightInc, Width+WidthInc+200)
    25. reduce_domain(TiledImage2, ROI, ImageReduced2)
    26. find_aniso_shape_model (ImageReduced2, ModelID, -0.39, 0.78, 0.95, 1.05, 0.95, 1.05, 0.5, 1, 0.5, 'least_squares', 0, 0.9, Row2, Column2, Angle2, ScaleR2, ScaleC2, Score2)
    27. dev_display_shape_matching_results (ModelID, 'green', Row2, Column2, Angle2, ScaleR2, ScaleC2, 0)
    28. vector_angle_to_rigid(Row2, Column2, Angle2, Row1, Column1, Angle1, HomMat2D)
    29. affine_trans_image(TiledImage2, ImageAffinTrans1, HomMat2D, 'constant', 'false')
    30. max_image(TiledImage1, ImageAffinTrans1, ImageMax)
    31. write_tuple (HomMat2D, 'HomMat2D.tup')
    这个是拼合代码,你需要的就是不用建模板改写仿射矩阵那部分,手动创建矩阵去仿射然后拼合即可!
    6
    473
     楼主| 发表于 2017-3-22 20:08:40 | 显示全部楼层
    RE: Image对齐
    非常感谢提供帮助
