查看: 3615|回复: 4
[已解决] halcon&MFC混合编程&图片脏污检测,求指点
7
21
470
发表于 2017-8-14 13:41:32 | 显示全部楼层 |阅读模式
检测图片上的脏污。halcon可以检测到,MFC不知道哪里不正确,有高人来指点一下么?
附上图片
halcon:(这个是可行的)
read_image (Image, 'C:/Users/N01605/Desktop/1.bmp')
Sigma1 := 30.0
Sigma2 := 5.0
gen_gauss_filter (GaussFilter1, Sigma1, Sigma1, 0.0, 'none', 'rft', Width, Height)
gen_gauss_filter (GaussFilter2, Sigma2, Sigma2, 0.0, 'none', 'rft', Width, Height)
sub_image (GaussFilter1, GaussFilter2, Filter, 1, 0)
rft_generic (GrayImage, ImageFFT, 'to_freq', 'none', 'complex', Width)
convol_fft (ImageFFT, Filter, ImageConvol)
rft_generic (ImageConvol, ImageFiltered, 'from_freq', 'n', 'real', Width)
scale_image_range (ImageFiltered, ImageScaled, 0, 255)
threshold (ImageScaled, Region, 1, 255)
connection (Region, ConnectedRegions)
select_shape_proto (ConnectedRegions, ConnectedRegions, SelectedRegions, 'distance_contour', 1, 999)
opening_circle (SelectedRegions, RegionOpening, 7.5)
dev_display (Image)
dev_display (RegionOpening)
MFC:(看不到效果)
//Halcon13 API
        CRect rect;
        CRect rect2;
        CRect rect3;
        CRect rect4;
        GetDlgItem(IDC_STATIC_IMAGE1)->GetWindowRect(rect);
        GetDlgItem(IDC_STATIC_IMAGE2)->GetWindowRect(rect2);
        GetDlgItem(IDC_STATIC_IMAGE3)->GetWindowRect(rect3);
        GetDlgItem(IDC_STATIC_IMAGE4)->GetWindowRect(rect4);
        m_hWndImage = GetDlgItem(IDC_STATIC_IMAGE1)->GetSafeHwnd();
        m_hWndImage2 = GetDlgItem(IDC_STATIC_IMAGE2)->GetSafeHwnd();
        m_hWndImage3 = GetDlgItem(IDC_STATIC_IMAGE3)->GetSafeHwnd();
        m_hWndImage4 = GetDlgItem(IDC_STATIC_IMAGE4)->GetSafeHwnd();
        OpenWindow(0,0,rect.Width(),rect.Height(),(Hlong)m_hWndImage,"visible","",&m_hWindowHandle);
        OpenWindow(0,0,rect2.Width(),rect2.Height(),(Hlong)m_hWndImage2,"visible","",&m_hWindowHandle2);
        OpenWindow(0,0,rect3.Width(),rect3.Height(),(Hlong)m_hWndImage3,"visible","",&m_hWindowHandle3);
        OpenWindow(0,0,rect4.Width(),rect4.Height(),(Hlong)m_hWndImage4,"visible","",&m_hWindowHandle4);
        //默认加载图像
        HObject Image,GaussFilter1,GaussFilter2,Filter,GrayImage,ImageFFT,ImageConvol,ImageFiltered,ImageScaled,Region,ConnectedRegions;
        HObject SelectedRegions,RegionOpening,ResultImage;
        HTuple Width,Height;
        HTuple sigma1 = 5.0;
        HTuple sigma2 = 30.0;
        //HTuple GausFilter1;
        //ReadImage(&Image,"clip");
        ReadImage(&Image,"C:\\Users\\jackgu\\Desktop\\脏污图片\\1.bmp");
        GetImageSize(Image,&Width,&Height);
        GenGaussFilter(&GaussFilter1,sigma1,sigma1,0.0,"none","rft",Width,Height);
        GenGaussFilter(&GaussFilter2,sigma2,sigma2,0.0,"none","rft",Width,Height);
        SubImage(GaussFilter1,GaussFilter2,&Filter,1,0);
        DispObj(Image,m_hWindowHandle);//显示高斯滤波后的差分图在第1个控件
        Rgb1ToGray(Image,&GrayImage);
        SetPart(m_hWindowHandle,0,0,Height,Width);
        DispObj(GrayImage,m_hWindowHandle2);//显示灰度图在第2个控件
        RftGeneric(GrayImage,&ImageFFT,"to_freq","none","complex",Width);
        ConvolFft(ImageFFT,Filter,&ImageConvol);
        RftGeneric(ImageConvol,&ImageFiltered,"from_freq","none","real",Width);
        ScaleImage(ImageFiltered,&ImageScaled,0,255);
        DispObj(ImageFiltered,m_hWindowHandle3);//显示在第3个
        Threshold(ImageScaled,&Region,1,255);
        //DispObj(ImageScaled,m_hWindowHandle);
        Connection(Region,&ConnectedRegions);
        SelectShapeProto(ConnectedRegions,ConnectedRegions,&SelectedRegions,"distance_contour",1,9999);
        OpeningCircle(SelectedRegions,&RegionOpening,7.5);
        DispObj(RegionOpening,m_hWindowHandle4);
1.zip
322.96 KB, 下载次数: 17, 下载积分: 金币 -2
脏污图片
7
21
470
 楼主| 发表于 2017-8-15 15:48:08 | 显示全部楼层
已找到问题出在哪了,窗口配置大小不对,图片没有缩放显示。
还有一个问题,
threshold (ImageScaled,&Region, 1, 255);
connection (Region, &ConnectedRegions);
select_shape_proto (ConnectedRegions, ConnectedRegions, &SelectedRegions, "distance_contour", 1, 999);
opening_circle(SelectedRegions, &RegionOpening, 7.5);
我要如何将这些显示在一张图片里面?
SelectedRegions显示不出来
    2021-6-11 12:17
  • 签到天数: 348 天
    [LV.8]以坛为家I
    16
    49
    138
    突出贡献优秀版主荣誉管理论坛元老切换助手验证会员
    发表于 2017-8-16 12:36:49 | 显示全部楼层
    还有一个问题,
    threshold (ImageScaled,&Regi ...
    你可以把区域concat到一起然后重新排下显示顺序
    disp_obj(Image,WindowHandle)  //图片
    disp_obj(Objests,WindowHandle) //其他所有的区域或者轮廓的元组
    disp_message之类的就可以了。
    图片最大放最下面,上面依次放其他区域或者轮廓,然后放显示的字。
    (注意:请记得set_color,否则你显示的区域或者轮廓可能是白色的)
    7
    21
    470
     楼主| 发表于 2017-8-17 09:40:05 | 显示全部楼层
    感谢楼上耐心的指点
