查看: 4757|回复: 9
[待解决] Remote Debugging feature in HALCON 13
    昨天 14:03
  • 签到天数: 379 天
    12
    56
    Rank: 4Rank: 4
    1421
    活跃会员切换助手验证会员
    发表于 2017-8-25 22:37:10 | 显示全部楼层 |阅读模式
    test.png I want to debug my Hdev application with remote debugging feature. I made all of process step by step. But I have not seen any codes in program window. I don't use '.hdvp' , I used '.hdev'. (All of steps are ok. c# + local host [port 57786] + debugger connection.  Only problem is "is not seen any code in program window")
    前天 09:30
  • 签到天数: 1263 天
    连续签到: 6 天
    417
    1720
    6197
    发表于 2017-8-27 18:12:47 | 显示全部楼层
    which romote tool are you chosing?
    昨天 14:03
  • 签到天数: 379 天
    12
    56
    Rank: 4Rank: 4
    1421
    活跃会员切换助手验证会员
     楼主| 发表于 2017-8-28 13:16:47 | 显示全部楼层
    My c# codes like this
    MyEngine.SetEngineAttribute("debug_password", "pass");
    MyEngine.SetEngineAttribute("debug_wait_for_connection", "true");
    MyEngine.StartDebugServer();
    前天 09:30
  • 签到天数: 1263 天
    连续签到: 6 天
    417
    1720
    6197
    发表于 2017-8-28 13:44:46 | 显示全部楼层
    You can provide us with the code if possible,we have never do like this,because of the performance! our email address is : szvbt@szvbt.com
    昨天 14:03
  • 签到天数: 379 天
    12
    56
    Rank: 4Rank: 4
    1421
    活跃会员切换助手验证会员
     楼主| 发表于 2017-8-28 14:59:05 | 显示全部楼层
    I created a simple example for you and upload files on dropbox. There is a video in folder about problem.
    https://www.dropbox.com/sh/qh23z73bcg42rps/AACCWcwzka-RgFN0sNZK0jOBa?dl=0
    昨天 14:03
  • 签到天数: 379 天
    12
    56
    Rank: 4Rank: 4
    1421
    活跃会员切换助手验证会员
     楼主| 发表于 2017-8-29 15:24:53 | 显示全部楼层
    When I used "HDevProcedure" and "HDevProcedureCall", I haven't any problem.(it is working)
    But when I used "HDevProgram" and "HDevProgramCall", it is not working well.(I haven't seen any codes on program window while it is working.)
    Does HALCON support these commands while it is on debugging mode, doesn't it?
    5 天前
  • 签到天数: 859 天
    188
    925
    5532
    发表于 2017-8-29 22:38:03 | 显示全部楼层
    China can's access the website! You can compress your files into a zip file  and send to us by email!
    昨天 14:03
  • 签到天数: 379 天
    12
    56
    Rank: 4Rank: 4
    1421
    活跃会员切换助手验证会员
     楼主| 发表于 2017-9-1 03:11:21 | 显示全部楼层
    Hi Friends,
    I sent files to you with an e-mail and uploaded files on onedrive.
    Thanks for help.
    https://1drv.ms/u/s!ApfbTeA2nUXni3RGUqh3PZlGAVqN
    前天 09:30
  • 签到天数: 1263 天
    连续签到: 6 天
    417
    1720
    6197
    发表于 2017-9-1 14:17:21 | 显示全部楼层
    Halcon_ 发表于 2017-9-1 03:11
    Hi Friends,
    Thanks for help.
    yes ,the files we had received and tested , but it occured an error! NULL pointer,  Halcon #error:20019 "empty auto ref pointer"  ,the Csharp application can't  go on.
    the hdevelop showed  like "  downloading procedure data form application! " I thought is't maybe your  program's issue!
    you can try to reference  it's examples
    前天 09:30
  • 签到天数: 1263 天
    连续签到: 6 天
    417
    1720
    6197
    发表于 2017-9-1 16:51:04 | 显示全部楼层
    it's own demo can running!  I found it's working file is *.hdvp(procedures),not hdevelop file! it's correct?every external procedure is HDevProcedure's object. QQ截图20170901170315.png
    1. mProcPreprocess = new HDevProcedure("preprocess_nuts");
    and you can use HDevProcedureCall's object to call it.
    1. mCallPreprocess = mProcPreprocess.CreateCall();
    and start debug server
    1. MyEngine.SetEngineAttribute("execute_procedures_jit_compiled", "false");
    2.                 // Set debug parameters
    3.                 MyEngine.SetEngineAttribute("debug_port", 57786);
    4.                 MyEngine.SetEngineAttribute("debug_password", "123456");
    5.                 //MyEngine.SetEngineAttribute("debug_wait_for_connection","true");
    6.                 // Start debug server
    7.                 MyEngine.StartDebugServer();
    you can show an image and press the inspect button,it's funcion like
    1. mCallPreprocess.SetWaitForDebugConnection(true);
    2.             mCallPreprocess.SetInputIconicParamObject("Image", mImage);
    3.             mCallPreprocess.Execute();
    4.             mImageFiltered = mCallPreprocess.GetOutputIconicParamImage("ImageFiltered");
    5.             hWindowControl1.HalconWindow.DispImage(mImageFiltered);
    after you pressed,the breakpoint in HDevelop came out,press F6 to continue,when completed, the Iconic Param Object is done.
