查看: 2865|回复: 1
[未解决] Create shape model
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
    发表于 2017-9-12 16:19:23 | 显示全部楼层 |阅读模式
    Hi
    I want to create shape model using funtion of "create_scaled_shape_model". I created model like codes on below. But I think it is not well %100. Sometimes it is not found any models in images. Do you have else idea about for create model?(filter, processing, threshold, ...)
    Thanks.
    1. read_image(Image , 'screw')
    2. decompose3 (Image, Red, Green, Blue)
    3. trans_from_rgb (Red, Green, Blue, Hue, Saturation, Intensity, 'hsi')
    4. gen_rectangle1 (selected, 60.0146, 65.4956, 159.52, 190.606)
    5.         reduce_domain(Intensity,selected,ImageReduced)
    6.
    7. MaxLineWidth := 6
    8. Contrast := 65
    9. calculate_lines_gauss_parameters (MaxLineWidth, [Contrast,0], Sigma, Low, High)
    10. lines_gauss (ImageReduced, edges, Sigma, Low, High, 'light', 'true', 'parabolic', 'true')
    11. AngleStart := 0
    12. AngleExtent := rad(360)
    13. AngleStep := 'auto'
    14. ScaleMin := 0.5
    15. ScaleMax := 1.5
    16. ScaleStep := 'auto'
    17. Optimization := 'none'
    18. Metric := 'ignore_local_polarity'
    19. Contrast := [10 , 25 , 67]
    20. **Contrast := [12 , 25 , 10]
    21. MinContrast := 10
    22. Numlevels_shape_model_ := 4
    23. **************************************
    24. create_scaled_shape_model_xld(edges, Numlevels_shape_model_ , AngleStart, AngleExtent, AngleStep,ScaleMin,ScaleMax,ScaleStep,Optimization,Metric,MinContrast,ModelID)
    25. get_shape_model_contours (ShapeModel, ModelID, 1)
    5 小时前
  • 签到天数: 680 天
    147
    759
    4484
    发表于 2017-9-13 11:08:15 | 显示全部楼层
    Your effect of light source is not well.  try to make it brighter.
    "create_scaled_shape_model" this procedure require x and y scaled synchronously.
