查看: 2615|回复: 13
[已解决] DirectShow multi camera resolution error
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
    发表于 2017-11-9 16:35:45 | 显示全部楼层 |阅读模式
    I will use a webcam camera like Logitech c920. It supports "2304x1536" resolution. I used it succesfully for single camera. But when I use two cameras(2304x1536) , second camera is connecting and it failed 2-3 seconds later. (capture timeout error).
    Also, when I set cameras resolution to (1920x1080), they are working well. According to me, Two cameras which are setting to (2304x1536 resolution) , aren't working at same time. Why doesn't it work well for multi cameras?
    Thanks.
    My codes:
    1. HTuple AcqHandle1, AcqHandle2;
    2. HObject Image1, Image2;
    3. HOperatorSet.OpenFramegrabber("DirectShow", 1, 1, 0, 0, 0, 0, "default", 8, "rgb", -1, "false", "[0] RGB24 (" + "2304x1536" + ")", "[0] Logitech HD Pro Webcam C920", 0, -1, out AcqHandle1);
    4. HOperatorSet.GrabImageStart(AcqHandle1, -1);
    5. Thread.Sleep(3000);// wait seconds
    6. HOperatorSet.GrabImageAsync(out Image1 , AcqHandle1 , -1);
    7. HOperatorSet.OpenFramegrabber("DirectShow", 1, 1, 0, 0, 0, 0, "default", 8, "rgb", -1, "false", "[0] RGB24 (" + "2304x1536" + ")", "[1] Logitech HD Pro Webcam C920", 0, -1, out AcqHandle2);
    8. HOperatorSet.GrabImageStart(AcqHandle2, -1);
    9. Thread.Sleep(3000);// wait seconds
    10. HOperatorSet.GrabImageAsync(out Image2, AcqHandle2, -1);
    前天 09:50
  • 签到天数: 975 天
    连续签到: 11 天
    382
    1559
    7390
    发表于 2017-11-9 17:19:50 | 显示全部楼层
    maybe your workstation is not supported by two cameras.  capture codes:
    1. HOperatorSet.GrabImageAsync(out Image1 , AcqHandle1 , -1);
    try  to made it  like:
    1. HOperatorSet.GrabImage(out Image1 , AcqHandle1);
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-9 18:04:44 | 显示全部楼层
    I tried it but nothing changed. There is a led on webcam. It lights when run this command(HOperatorSet.GrabImageStart (AcqHandle1, -1);). When I run it for second camera, led is lighting 2-3 seconds and its status is been off later. And after, I ran this command ("HOperatorSet.GrabImage (outImage2, AcqHandle2);") , it failed to timeout error.
    Note: My Workstation isn't running any problem by two cameras with (1920x1080 and below resolution ).
    前天 09:50
  • 签到天数: 975 天
    连续签到: 11 天
    382
    1559
    7390
    发表于 2017-11-9 21:35:20 | 显示全部楼层
    Maybe your bandwidth isn't enough or lower voltage
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-10 00:35:58 | 显示全部楼层
    I tried it with usb 3.0 hub (external power - 5v 6A). So, I think, this problem is not related to lower voltage.
    Is USB3.0 enough for bandwith or how can I research it?
    At this time, It is working well sometimes.(2 cameras - 2304x1536 resolution) But It is not working generally.
    For example, it is running well(2 cameras - 2304x1536).(Visual studio debug mode.) After, I closed visual studio and reopen. But it is not working this time. :'(  It is boring.
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-10 04:00:57 | 显示全部楼层
    And I tried example which is shown below.
    Halcon example => "directshow_2cameras.hdev"
    In example:
    // Working well
    MyCameraType1 := 'default'
    MyCameraType2 := 'default'
    // Working well
    MyCameraType1 := 'RGB24 (2304X1536)'
    // Working well
    MyCameraType2 := 'RGB24 (2304X1536)'
    // first camera is woking well, but second camera isn't working. (sometimes both of them are working :L)
    // everytime fist camera OK.
    前天 09:50
  • 签到天数: 975 天
    连续签到: 11 天
    382
    1559
    7390
    发表于 2017-11-10 10:52:20 | 显示全部楼层
    Which halcon version  do  you used? I can't found anything about example like "directshow_2cameras.hdev"
    your hub's bandwidth must be shared! you can use a pc with PCI-E usb card! or reduce the framerate!
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-10 13:17:56 | 显示全部楼层
    I use version-13.0.  The example is shown below.
    * Example for the usage of a DirectShow compatible capture device
    * (grabbing from two devices)
    dev_update_off ()
    info_framegrabber ('DirectShow', 'general', GeneralInfo, GeneralInfoValues)
    info_framegrabber ('DirectShow', 'revision', RevInfo, RevInfoValues)
    * Check your installed camera devices:
    info_framegrabber ('DirectShow', 'camera_types', CameraTypeInfo, CameraTypeInfoValues)
    info_framegrabber ('DirectShow', 'info_boards', BoardInfo, BoardInfoValues)
    * Check for the proper CameraType, Device, and Port settings
    * (see output of info_framegrabber(..,'info_boards',..))
    * MyCameraType1 := 'RGB24 (640x480)'
    * MyCameraType2 := 'RGB24 (640x480)'
    MyDevice1 := '0'
    MyDevice2 := '1'
    MyPort1 := -1
    MyPort2 := -1
    open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', -1, 'gray', -1, 'false', MyCameraType1, MyDevice1, MyPort1, -1, AcqHandle1)
    open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', -1, 'gray', -1, 'false', MyCameraType2, MyDevice2, MyPort2, -1, AcqHandle2)
    * Query current settings:
    get_framegrabber_param (AcqHandle1, ['camera_type','frame_rate'], CurrentSettings1)
    get_framegrabber_param (AcqHandle2, ['camera_type','frame_rate'], CurrentSettings2)
    grab_image (Image1, AcqHandle1)
    grab_image (Image2, AcqHandle2)
    get_image_size (Image1, Width1, Height1)
    get_image_size (Image2, Width2, Height2)
    dev_close_window ()
    dev_close_window ()
    dev_open_window (0, 0, Width1 / 2, Height1 / 2, 'black', WindowHandle1)
    dev_open_window (0, Width1 / 2 + 20, Width2 / 2, Height2 / 2, 'black', WindowHandle2)
    count_seconds (SecondsOld)
    while (1)
        dev_set_window (WindowHandle1)
        dev_display (Image1)
        dev_set_window (WindowHandle2)
        dev_display (Image2)
        count_seconds (SecondsNew)
        FrameRate := 1 / (SecondsNew - SecondsOld)
        SecondsOld := SecondsNew
    endwhile
    close_framegrabber (AcqHandle1)
    close_framegrabber (AcqHandle2)
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-10 14:36:45 | 显示全部楼层
    And I tried it which is shown on below. it is working well.
    Is reason of problem based on bandwith problem certainly?
    1. start first camera
    2. capture from first camera
    3. stop first camera
    4. start second camera
    5. capture from second camera
    6. stop second camera
    while (true)
    open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', 8, 'rgb', -1, 'false', 'RGB24 (2304x1536)', '[0] Logitech HD Pro Webcam C920', 0, -1, AcqHandle)
    grab_image_start (AcqHandle, -1)
        grab_image_async (Image, AcqHandle, -1)
        dev_display (Image)
    close_framegrabber (AcqHandle)
    open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', 8, 'rgb', -1, 'false', 'RGB24 (2304x1536)', '[1] Logitech HD Pro Webcam C920', 0, -1, AcqHandle2)
    grab_image_start (AcqHandle2, -1)
        grab_image_async (Image2, AcqHandle2, -1)
    endwhile
    2020-9-25 14:09
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-12 23:22:13 | 显示全部楼层
    I resolved the problem. I tried it with a computer which has more performance , and it is working well now.
    According to me, the problem was about with mainboard performance.
    Thanks for your information.
