查看: 2129|回复: 10
[已解决] Give an unique id number for a webcam(directshow)
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
    发表于 2017-11-15 00:18:53 | 显示全部楼层 |阅读模式
    HiI want to control multiple cameras with halcon. Can I give an id number(unique) for every webcam? Or, Can I use it with numbers which is like as serial numbers or vendor id or device id?
    Thanks for your advices.
    耍酷
    昨天 10:00
  • 签到天数: 957 天
    380
    1554
    7294
    发表于 2017-11-15 10:24:20 | 显示全部楼层
    yes,you can initialization by serial numbe,you need encapsulate functions  as a class
    like :https://www.51halcon.com/thread-794-1-1.html c# code!
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-16 00:26:09 | 显示全部楼层
    I can't access this link. It was an error which name si "the page is not available"
    耍酷
    昨天 10:00
  • 签到天数: 957 天
    380
    1554
    7294
    发表于 2017-11-16 09:58:52 | 显示全部楼层
    you can try again,if the problem persists,maybe network's issue.
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-19 17:21:06 | 显示全部楼层
    I can access now. Thank you.
    耍酷
    昨天 10:00
  • 签到天数: 957 天
    380
    1554
    7294
    发表于 2017-11-19 17:24:01 | 显示全部楼层
    you are welcome!
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-20 14:01:35 | 显示全部楼层
    I can't use it with my c# project, because "using MvCamCtrl.NET" is undefined. How can I add it as a reference for my project?
    Thanks.
    耍酷
    昨天 10:00
  • 签到天数: 957 天
    380
    1554
    7294
    发表于 2017-11-20 15:01:23 | 显示全部楼层
    you can use function like 'initcame(string sn)' for reference! the namespace "using MvCamCtrl.NET" is HikCamera's SDK,for yours,change this code for your devices!
    5 天前
  • 签到天数: 377 天
    12
    56
    Rank: 4Rank: 4
    1579
    活跃会员切换助手验证会员
     楼主| 发表于 2017-11-20 20:05:30 | 显示全部楼层
    I queried serial number on c# succesfully. But, how can I use it with Halcon functions? Halcon functions don't use serial number properties, do it?
    like as ->
    HOperatorSet.OpenFramegrabber("DirectShow", 1, 1, 0, 0, 0, 0, "default", 8, "rgb", -1, "false", "[0] mjpg (1920x1080)", "[0] Logitech HD Pro Webcam C920", 0, -1, out AcqHandle[Int32.Parse(clNo)]);
    And, I showed with an image on below.
    耍酷
    昨天 10:00
  • 签到天数: 957 天
    380
    1554
    7294
    发表于 2017-11-20 21:32:40 | 显示全部楼层
    halcon codes coudn't init camera by serial number.you can init cam by camera's sdk only!
