返回列表 发新帖
[文档] Halcon 17.12 Progress 安装教程 步骤详解
绝地武士 发表于 2020-5-20 16:15:21 | 显示全部楼层
笨小孩的眼泪 发表于 2020-3-5 20:05
那vs2012能不能用Halcon插件呢?
你可以运行misc下面类似“HALCON_Variable_Inspect.vsix”这样的vs插件,装不了会提示你的
点开日志可以看到类似下面内容:
2020/5/20 16:11:06 - Microsoft VSIX Installer
2020/5/20 16:11:06 - -------------------------------------------
2020/5/20 16:11:06 - Initializing Install...
2020/5/20 16:11:07 - 扩展详细信息...
2020/5/20 16:11:07 -         Identifier         : 5d46db4f-d2c0-4605-889e-8c30ad19ceee
2020/5/20 16:11:07 -         Name               : HALCON Variable Inspect
2020/5/20 16:11:07 -         Author             : MVTec Software GmbH
2020/5/20 16:11:07 -         Version            : 1.0
2020/5/20 16:11:07 -         Description        : Visual Studio extension to inspect the HALCON data types HObject and HTuple in Debug mode.
2020/5/20 16:11:07 -         Locale             : en-US
2020/5/20 16:11:07 -         MoreInfoURL        : http://www.halcon.com/
2020/5/20 16:11:07 -         InstalledByMSI     : False
2020/5/20 16:11:07 -         SupportedFrameworkVersionRange : [4.0,4.5]
2020/5/20 16:11:07 -         SignatureState     : InvalidCertificate
2020/5/20 16:11:07 -         SignedBy           : MVTec Software GmbH
2020/5/20 16:11:07 -         Certificate Info   :
2020/5/20 16:11:07 -                 -------------------------------------------------------
2020/5/20 16:11:07 -                 [Subject]       : E=info@mvtec.com, CN=MVTec Software GmbH, O=MVTec Software GmbH, L=Munich, S=Bavaria, C=DE
2020/5/20 16:11:07 -                 [Issuer]        : CN=GlobalSign CodeSigning CA - G2, O=GlobalSign nv-sa, C=BE
2020/5/20 16:11:07 -                 [Serial Number] : 11217E8EFA7CEE1AFDEE64C7F491C59B7377
2020/5/20 16:11:07 -                 [Not Before]    : 2013/2/5 23:34:57
2020/5/20 16:11:07 -                 [Not After]     : 2016/2/6 23:34:57
2020/5/20 16:11:07 -                 [Thumbprint]    : 22C9E9A8C8C38604F942CCE7B187ECC207238CB4
2020/5/20 16:11:07 -         支持的产品              :
2020/5/20 16:11:07 -                 Microsoft.VisualStudio.Ultimate
2020/5/20 16:11:07 -                         Version : [10.0]
2020/5/20 16:11:07 -                         Version : [11.0]
2020/5/20 16:11:07 -                         Version : [12.0]
2020/5/20 16:11:07 -                 Microsoft.VisualStudio.Premium
2020/5/20 16:11:07 -                 Microsoft.VisualStudio.Pro
2020/5/20 16:11:07 -         引用                 :
2020/5/20 16:11:07 -                 Identifier   : Microsoft.VisualStudio.MPF
2020/5/20 16:11:07 -                 Name         : Visual Studio MPF
2020/5/20 16:11:07 -                 Version      : [10.0,)
2020/5/20 16:11:07 -                 Nested       : No
2020/5/20 16:11:07 - 签名详细信息...
2020/5/20 16:11:07 -         Extension is signed with an invalid certificate
2020/5/20 16:11:07 -                 (NotTimeValid)      : 根据当前系统时钟或签名文件中的时间戳验证时要求的证书不在有效期内。
2020/5/20 16:11:07 - 正在搜索适用的产品...
2020/5/20 16:11:07 - 找到的已安装产品 - Microsoft Visual Studio Enterprise 2015
2020/5/20 16:11:07 - 找到的已安装产品 - Microsoft Visual Studio Professional 2015
2020/5/20 16:11:07 - 找到的已安装产品 - Microsoft Visual Studio Community 2015
2020/5/20 16:11:07 - 找到的已安装产品 - Microsoft Visual Studio 2015 Shell (Integrated)
2020/5/20 16:11:07 - 找到的已安装产品 - 全局位置
2020/5/20 16:11:07 - VSIXInstaller.NoApplicableSKUsException: 此扩展不能安装在任何当前安装的产品上。
   在 VSIXInstaller.App.InitializeInstall(Boolean isRepairSupported)
   在 VSIXInstaller.App.InitializeInstall()
   在 System.Threading.Tasks.Task.InnerInvoke()
   在 System.Threading.Tasks.Task.Execute()
红色表示插件只支持这些vs版本,而蓝色的部分表示你电脑上有的vs版本,自己对照下就知道为啥装不了了!
从上面可以看出,Halcon12支持的版本是Ultimate、Premium、Pro版本中的10到12之间,如果你的vs12属于这些版本就可以,如果是Express的12就用不了!
笨小孩的眼泪 发表于 2020-5-28 14:55:10 | 显示全部楼层
点开日志可以 ...
好的,谢谢
qq843900174 发表于 2020-7-1 15:14:11 | 显示全部楼层
MARK MARK MARK
Andy99 发表于 2023-7-21 14:51:25 | 显示全部楼层
5.选择分支平台,建议安装x86,后期再安装x64,避免默写内容不兼容导致需要更改!然后“NEXT->”;;;;我先装了32位的,重新点击安装的exe,为啥不能给我选择x64?想问这是在哪里可以安装x64?
Andy99 发表于 2023-7-21 15:53:19 | 显示全部楼层
5.选择分支平台,建议安装x86,后期再安装x64,避免默写内容不兼容导致需要更改!然后“NEXT->”;;;;我 ...
助手那里显示可以选择x64和86,切换之后,打开项目报错21010,#2379No CodeMeter Runtime installed (version 6.30 or  later required)。点进安装路径MVTec\HALCON-17.12-Progress\bin\x64-win64文件夹没有hdevelop.exe。
